R59 Window Clearance
Old Aug 30, 2013 | 10:02 AM
kilpa482's Avatar
kilpa482
Window Clearance
New guy here, searched around and didn't see anything, i may be blind. Is it normal for the window on the passenger side not to go all the way inside the door? My drivers side goes all the way down, but my passenger side sticks up just a little bit, maybe a quarter of an inch. The dealership says this is normal.
Thanks!
Old Aug 30, 2013 | 05:25 PM
Mr. T's Avatar
Mr. T
Thanks!
Both windows on my Roadster go al the way down. No glass visible.
Old Aug 30, 2013 | 05:30 PM
Gil-galad's Avatar
Gil-galad
Originally Posted by mr. T
both windows on my roadster go al the way down. No glass visible.
+1
Old Aug 30, 2013 | 06:21 PM
KennyR's Avatar
KennyR
I'm waiting for my Roadster, but my previous Convertible S had a similar problem with the driver's window not completely closing (about 1/2 inch), as well as something rubbing on the glass when it raised and lowered that left a 1/2 inch vertical streak from top to bottom. My dealer adjusted it without a question at my first return visit.
If your dealer says "it's normal", have him show you the same thing on another Roadster in the showroom.
Old Aug 31, 2013 | 09:07 AM
chosmister's Avatar
chosmister
Agreed!
My windows definitely go down all the way
Old Sep 1, 2013 | 05:05 AM
kilpa482's Avatar
kilpa482
Thanks, I think ill do this when I go in for the first oil change, it looks like they were able to get it down a tiny bit, but the window is still above the frame on the inside of the car.
Old Sep 1, 2013 | 06:47 AM
Mr. T's Avatar
Mr. T
... and take a picture of his expression with you phone.
Old Sep 2, 2013 | 05:19 AM
kilpa482's Avatar
kilpa482
Sent and email to the service rep with a cc to his manger today, hopefully they will try to resolve the issue. I really don't want to be in a loaner for another 3 days without a solution. Heres a pic, maybe i'm too picky.
Old Sep 2, 2013 | 07:52 AM
KennyR's Avatar
KennyR
You may be "picky", but to me, being able to rest your arm on the door with the top down is part of the Roadster experience! While it's not a critical or safety issue, your pic is definitely "Not Normal" (as MINI marketing says)! I just waited until I had a regular service appointment for an oil change, and they fixed it in about 30 minutes. The body shop tech just popped the door panel off and made some adjustments, no parts needed, and you shouldn't have to need a loaner for 3 days.
Old Sep 3, 2013 | 02:54 PM
TheZlog's Avatar
TheZlog
that is what my passenger window looks like too.
Old Sep 4, 2013 | 05:14 PM
spiney's Avatar
spiney
My windows don't quite go all the way down into the door. They end up just a hair below the top of the outside rubber seal, so they are visible from the inside, but not from the outside.
Old Sep 19, 2013 | 05:25 PM
kilpa482's Avatar
kilpa482
For anyone curious, mini had asked me to do this survey on my satisfaction with the service issue. I ended up going back to the dealer, who told me they have tried and the the window can't be adjusted any lower. I stressed the point that the drivers side is fine, and couldnt see why the passenger side would be any different. I assume its a symmetrical car. They opened a technical case, and had it magically fixed 2 days later. I thought it was funny how what I was told was impossible twice was fixed so quickly. They claim to have adjusted the regulator. They did spend half a day water testing the window as they were afraid of leaks.
Old Sep 20, 2013 | 06:02 AM
TG.'s Avatar
TG.
I thought to look at mine yesterday and one is very very slightly lower than the other but both are below the outer seal edge and visible from the inside.
I do not feel the window when resting my arm on the door.
USNAE2
16
Jun 17, 2022 07:17 AM
M7Speed
Jul 10, 2018 09:26 AM
bahman
Feb 14, 2016 10:29 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
rt808
Sep 25, 2015 01:59 PM
