R57 2010 jcw cabrio door popping noise
Old Aug 29, 2013 | 05:59 PM
GFB's Avatar
GFB
Today when opening my driver side door all the way, I heard two distinct and loud popping noises. First one happens about halfway open, the second about 75% of the way.
No idea what material it sounds like, it's almost dampened...if that makes any sense. Thoughts?
Old Aug 29, 2013 | 09:02 PM
gr8ful's Avatar
gr8ful
I think door has two detents and maybe need likes at. Could be just a lube issue. Does it do it
Opening and closing? Let us know what you out.
Old Aug 30, 2013 | 11:53 AM
furbyslayer's Avatar
furbyslayer
This happened on my 2009 r56. Check the door brake attach point at the car body. Mine had a bolt that was loose and it made a noise like you are describing. All it took is tightening with a torx bit if it is in fact loose, you may see the attach plate quickly shift at the stop points... But YMMV
Last edited by furbyslayer; Sep 2, 2013 at 11:01 AM. Reason: Clarification, I know what I meant...
Old Aug 30, 2013 | 12:09 PM
Check the torx bolts on the door brake to make sure its secure and lube the hinges #3 and #2 and also the door brake. If you stiil have noise the door brake might need replaced.
Front Door Brake - Used on the front door both passenger and driver side.
http://www.ecstuning.com/Search/SiteSearch/51217176811/ES90052/
Mounts to the door jam body and the door frame.
Old Aug 31, 2013 | 12:35 PM
GFB's Avatar
GFB
Was the bolt on #8. Waaay loose.
Creak and squeak free now.
Old Sep 3, 2013 | 05:44 AM
Great,
Thanks for the update.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Dec 23, 2015 10:36 AM
Cal45fan
Aug 11, 2015 03:50 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
