Door unlocked when you pull the handle, but not with button?
Old Aug 29, 2013 | 04:25 AM
nrowensby's Avatar
nrowensby
My passenger door will unlock when you pull the inside handle, but won't unlock via any power options (unlock button or while unlocked driver's door)... any suggestions?
It will lock via any/all methods, but not unlock unless you pull the inside handle.
Old Aug 29, 2013 | 04:43 AM
ZippyNH's Avatar
ZippyNH
Sounds like the actuator is broken....
Do you hear a sound when you TRY to unlock it with the button?
Old Aug 29, 2013 | 05:03 AM
Beachnmini's Avatar
Beachnmini
Did you hit the button 2x?
Old Aug 29, 2013 | 05:08 AM
+1 on what zippy said. Yea sounds like the lock mechanism itself, they tend to stick on the unlock part first and not unlock via the motor but will still lock until it get weak.
Here is a link:
https://www.northamericanmotoring.co...-question.html
And here is the diagram and list, while you are there is good to look everything over.
Here is the door diagram for the Gen 1 MINI R50 R52 R53.
#1 in the diagram
Door Lock Unit - Left ( Driver Side )
http://www.ecstuning.com/Search/SiteSearch/51200556768/
Door Lock Unit - Right ( Passenger Side )
http://www.ecstuning.com/Search/SiteSearch/51200556769/
Also.
If you ever have the inside handle not work and everything else is find , check the cable connection first.
Here is # 9 in the diagram that is the cable. Set between the lock and handle.
http://www.ecstuning.com/Search/SiteSearch/51217143538/
Dec 23, 2015 10:36 AM
joedotmac
Aug 28, 2015 01:04 PM
polotska
Aug 23, 2015 03:03 PM
coachvminis
Aug 17, 2015 01:42 PM
