Drivetrain Melted valve Cover
Old Aug 28, 2013 | 01:02 PM
dboard7's Avatar
dboard7
Melted valve Cover
Well installed the M7 heat shield and used it once at thetrack for 3 sessions and it decided to trap all of the heat and melt my valvecover… now it need to be replaced and it is not covered under warranty becausethe heat shield was installed. Dealer said just for the valve cover and gasketit will be around $600 not including labor. and there is a wire that runsthrough there that is part of the main harness that is probably damaged if sothe whole harness needs to be replaced. Im assuming this can be slightlycheaper If I find a small shop and have them do it but just wondering if anyonehas had a similar issue or any advice?
Old Aug 28, 2013 | 01:10 PM
MIKESGREENMINI's Avatar
MIKESGREENMINI
Either find a shop or do the work yourself. The dealer will just replace everything and not worry about fixing the problem. then charge you double the price.
Old Aug 28, 2013 | 01:13 PM
dboard7's Avatar
dboard7
That's what I was afraid of, I would like to try and tackle this myself not sure how difficult it is. Also does anyone out there know if there is a better valve cover maybe a (performance version) the may with stand heat better or work better than the stock one?
Old Aug 28, 2013 | 01:33 PM
dboard7's Avatar
dboard7
Picks of the damage
pics of what happened
Attached Thumbnails Melted valve Cover-photo-2.jpg   Melted valve Cover-photo-1.jpg
Old Aug 28, 2013 | 01:59 PM
NewCooperFanatic's Avatar
NewCooperFanatic
I say go after M7, that's some BS right there.
Old Aug 28, 2013 | 02:28 PM
InjectedGT's Avatar
InjectedGT
WOW. I'm with that guy above me. That's complete BS. Get in touch with M7 including the pictures you have there. I see no question, if nothing else was added there other than the heat shield, that the heat shield caused that.
Get a turbo blanket this time around. Keeps all the heat in the hot side of the turbo where it HELPS performace, but doesn't let the oil line, center bearing, or cold side get soaked in heat like that heat shield obviously causes. Let alone melting the damn valve cover!
Old Aug 28, 2013 | 02:42 PM
dboard7's Avatar
dboard7
I just emailed M7 and sent them the pics so ill keep everyone posted. Ill look into the blanket I was hoping this would actually have the same effect, it defiantly kept it hot lol I was able to find a new valve cover on ebay for 300 shipped im hoping nothing else was damaged but I don't want to tear it apart till I have the new cover in hand. in the mean time if you have a heat shield on I would suggest to take it off a hood scoop is cheaper than the valve cover if it melts.
Old Aug 28, 2013 | 02:46 PM
RobMuntean's Avatar
RobMuntean
Glad I never put any M7 parts on my car, but as for your valve cover, do it yourself. Plus it'll be a lot cheaper. My valve cover cost me $327. But mine is an N18 though so price will vary between the N14 and mine.
Good luck, and if you do it yourself, do a "How-To" for others.
Old Aug 28, 2013 | 06:21 PM
mbwicz's Avatar
mbwicz
I have been running the same heat shield as you, but I have not tracked my car. My valve cover was leaking (back side of the engine, not heat related). I got a replacement from ECS tuning for about the same money as you paid. It was an easy replacement, nothing to be nervous about.
Mike
Old Aug 28, 2013 | 06:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
$600 crap, need to raise my prices
http://www.waymotorworks.com/valve-c...-cooper-s.html
Old Aug 28, 2013 | 09:18 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by WayMotorWorks
Way, why is a N14 valve cover cost more than an N18? Mine was priced at $327 with gaskets and all.
Old Aug 28, 2013 | 09:31 PM
jordan.burks's Avatar
jordan.burks
I think it has to do with the n14 PCV system being included in the valve cover. the n18 has a different pcv system so different valve cover.
Old Aug 29, 2013 | 07:07 AM
dboard7's Avatar
dboard7
Mine may have been cheaper because I bought it off ebay but before I bought it I checked my vin number to make sure it would work with my car, I see a lot of people with good reviews of the m7 shield but after seeing this I would recommend everyone against it. if it is trapping in this much heat imagine what it is doing to your turbo if your trying to get performance out of it your just going backwards having your turbo get this hot.
Old Aug 29, 2013 | 07:14 AM
dboard7's Avatar
dboard7
by the way still nothing back from M7, this is already not looking good, there was just an issue yesterday with evolve tuning and within one day not even contacting the company they were sending him a pm to get things cleared up,
https://www.northamericanmotoring.co...ny-evolve.html
Old Aug 29, 2013 | 07:51 AM
PinkMiso's Avatar
PinkMiso
I have the same problem but having been running with no heat shield for 50k miles so no surprise there. I actually have a small hole melted right next to the oil line. Next step will be thermal wrap everything with no heat shield and a thermal blanket on the turbo which i feel will be the most effective method. As far as the harness i wouldn't worry too much. Let's just say i have had many parts of it come into contact with things they shouldn't and dangle in precarious locations during my projects and testing while in the beta zip tie mode and its pretty robust
Old Aug 29, 2013 | 08:03 AM
R56typeS's Avatar
R56typeS
I have the same little hole by the oil line, PinkMiso.
Old Aug 30, 2013 | 01:02 PM
TheMINIPartStore's Avatar
TheMINIPartStore
Wow, That is hot. I have seen that happen to a couple cars here at the store. Different shield but similar results.
If your interested we keep the valve covers in stock. Gaskets are included.
The part number is 11127646555
-Sean
http://www.theminipartstore.com/inde...partnum=accept
Old Aug 30, 2013 | 01:18 PM
dboard7's Avatar
dboard7
I wish they would say not to use it under certain circumstances or something
btw this is the 3rd day and still nothing back from M7 and now there is a 3 day weekend coming up, this is just terrible customer service on there end.
Old Aug 30, 2013 | 01:37 PM
InjectedGT's Avatar
InjectedGT
call? email? message?
Old Aug 30, 2013 | 01:41 PM
dboard7's Avatar
dboard7
No answer when called, Chad from Detroit Tuned (great shop awesome customer service!) actually called yesterday and said they would be emailing me back but I still haven't heard anything and I have emailed twice to them about this posted here and on facebook thinking they would see it everyone else has. seriously even a quick message to say hey were looking into this for you would be nice obviously they don't care enough about there customers to do that though. and it not like they don't have my contact info to get ahold of me because they just took my money last week...
Old Aug 30, 2013 | 01:55 PM
InjectedGT's Avatar
InjectedGT
Wow. That is **** poor customer service! And a **** poor product to hit the market without enough testing to have found this issue. It's a part you might expect people to buy for a perfomance vehicle, they didn't anticipate someone tracking their car once in a while with it on??? What kind of testing DID they do?
Old Aug 30, 2013 | 02:07 PM
dboard7's Avatar
dboard7
That's exactly what im saying, I was hoping for some sort of compensation because im our the cost of the heat shield and the new part for the car and my time its taken into contacting them and taking my car into the dealer and waiting and fixing the car and not being able to drive it until it is fixed
Old Aug 30, 2013 | 03:58 PM
NewCooperFanatic
Wanna know what's super jacked.....the user name M7TUNING posted a vendor announcement just yesterday.
So obviously they are still around....yet not replied to you. They're shooting themselves in the foot, if they haven't already.
Old Aug 30, 2013 | 04:05 PM
dboard7's Avatar
dboard7
Wow I just noticed that! messed up! I seriously hope other people see this and learn from my mistake at the least not to deal with this company and get there parts elsewhere.
Old Aug 31, 2013 | 11:14 AM
InjectedGT's Avatar
InjectedGT
Anything yet? I'm curious to see what they're doing... I mean calls/emails from a customer with a complaint getting completely blown off while they come on this forum to post up more promotions to get customers... Pathetic business tactics. "We don't test our ****, it might fail, it might cause issues, but once the sale is over, you're nobody to us" is exactly what I'm seeing here.
