Suspension front sway bar
Old Aug 27, 2013 | 08:58 AM
<05MINI>'s Avatar
<05MINI>
front sway bar
Hi I have a 2005 R53 I was looking at getting the hotchkis front sway bar. I already have the alta 22 mm rear sway bar. My question is will the front sway bar realy make that much of a difference. Is it worth spending $230 on or would my money be better spent elsewere. I was also looking at lowering the car as well which would be the better investment.
Old Aug 27, 2013 | 01:21 PM
cristo's Avatar
cristo
Alliance Member
I wouldn't. It will just make the MINI corner a little flatter at the expense of increased understeer and wheel spin.
Old Aug 27, 2013 | 02:10 PM
GreekDrifter91's Avatar
GreekDrifter91
front sway bar is not needed. its just gonna make you understeer, and thats no funn.
Old Aug 27, 2013 | 03:24 PM
quikmni's Avatar
quikmni
Spend the money on front camber plates instead. Fixed or adjustable. When you lower the car that would be the perfect time to install camber plates.
Old Aug 28, 2013 | 02:53 AM
<05MINI>'s Avatar
<05MINI>
Ok thanks for the advice. Ill probably just lower and instal the camber plates then.
W0TM8
Dec 19, 2019 07:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
