Navigation & Audio For the guys looking for a navi retrofit
Old Aug 19, 2013 | 10:55 AM
blue dragon's Avatar
blue dragon
Looks like standard auto wreckers has a car with it
http://standardautowreckers.net/asp/...sp?ID=18552707
(Not affiliated in anyway)
Old Aug 25, 2013 | 04:38 PM
bmrguy03's Avatar
bmrguy03
couldnt find it. what search criteria did you use?
Old Aug 28, 2013 | 07:48 AM
blue dragon
It was under fresh roadkill, but now its gone
Old Aug 28, 2013 | 09:04 AM
ASKtheteach's Avatar
ASKtheteach
From what I've read in other threads around here, it's a lot more involved than simply dropping in the nav unit. The wiring is different, it has an additional antenna, and in the second gen cars, the console is different to accommodate the joystick and buttons. Also, the car is coded by VIN to a specific speedo/nav unit, so it would not work correctly if it was installed. Not sure if the car can be coded to accommodate it, but I doubt it. There were some people who tried to add the Chrono pack to the first gen cars, and that didn't work either for the same reason.
Old Aug 28, 2013 | 06:06 PM
bmrguy03's Avatar
bmrguy03
From what I've read, there was one member that had successfully retrofitted the nav into his 2nd gen. And yes it takes some coding but nothing a little NCS Expert can't change.
Kimolaoha
Jul 5, 2023 01:04 PM
jeremy_reyes94
Aug 26, 2015 10:10 AM
Alwyn
Aug 26, 2015 04:53 AM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
eliseo1981
Aug 6, 2015 05:00 AM
