Wheel speed sensor problem
Old Aug 17, 2013 | 08:57 AM
SooperCoopers's Avatar
SooperCoopers
So, recently I had my tire pressure light, DSC light, and ABS light come on. After doing some research, I found that the cause was likely a wheel speed sensor. I replaced both wheel speed sensors hoping to fix the problem. Now, however, all the lights are STILL on, in addition to the "service engine soon" and "BRAKE" light that comes on....the light that is typically associated with leaving your ebrake engaged. It seems as if my computer is really confused at this point. I drove the car to see if the lifts would go away, and I also tried disconnecting and reconnecting the battery...any ideas what my next move should be?
Thanks!
SooperCoopers
Old Aug 17, 2013 | 09:53 PM
fr0mmagna's Avatar
fr0mmagna
Pull the check engine code. That one is logged atleast !!
Old Aug 18, 2013 | 06:59 AM
healey67's Avatar
healey67
just because you replaced the sensor doesn't mean the lights will just go away... You need to have the fault codes read and see if anything is still present, if not clear them and take it for a spin.
Toolman
Jan 20, 2016 06:50 AM
massmini03
Aug 12, 2015 11:19 AM
Dashdog
Aug 10, 2015 06:17 AM
MES11
Aug 8, 2015 10:21 AM
