Suspension H-sport strut brace
Old May 8, 2004 | 12:42 PM
discodan's Avatar
discodan
anyone have pics of this installed on their car? is there any drilling involved for the installation?
Old May 8, 2004 | 12:56 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I have the BMP struct brace that uses the bolts form the upper struct as mounting points. Hence, no additional drilling. Not sure about H-sport though. :smile:
Old May 8, 2004 | 10:58 PM
maxmini's Avatar
maxmini
We have the H-sport installed on the track car and to be honest I am not sure if there were any additional holes drilled as it was installed before I joined the company.We were just out at Buttonwillow Raceway with the H-Sport ( Hotchkis ) group for their annual track day today. Nice people , great day I will check tomorrow for you . I do know it uses only 2 bolts in any event.
Randy
Team M7
Old May 9, 2004 | 03:01 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I haven't seen many pics of this particular Tower strut brace installed. Most are BMP or others.
You use the existing strut tower nuts to secure the various braces.
Edit- See next post- H-sport requires drilling holes.
Some feel that there is some additional stiffness to the front end and some better performance on hard cornering at speed. Others feel that it may be more cosmetic than functional for street driving or the average MINI owner.
"An all-aluminum design, the Brace utilizes a solid, CNC formed 22mm center section with billet ends pieces. The center section itself has the necessary shape in order to clear the stock and most aftermarket air boxes. It comes with a brushed silver finish while the billet ends are anodized H Sport Blue. The Brace is easy to install and can be utilized with or without H Sport Camber Plates.
Retail price: $270.11"
http://www.h-sport.com/cgi-bin/EDCst...atalogno=20800
_________________
Aloha Hawaii
Old May 9, 2004 | 06:23 AM
ftbt's Avatar
ftbt
I had all of my suspension work done directly by H Sport. I elected not to have the strut brace installed because it would have required drilling new holes. See H Sports' detailed instructions: http://www.h-sport.com/bin/instructions/20800.pdf
ftbt
2002 Works Cooper S, Sn. 1165, DS/W; Sport + Premium + Alta CAI + Unichip + H Sport Springs, Competition Front & Rear Sway Bars, Rear Camber Control Arms + 17" Team Dynamics Pro Race 1's; 215-45-17 Kumho MX's + AP Racing Formula Big Brakes, X Drilled + Slotted Rotors, Goodridge SS Lines + Clear Bra + Cobra Daytona Seats + Schroth Harness and a full tank of 100 octane ... life is good!
2002 CVT Cooper LY/W + Sport + 17" S Lites & Pirelii Euforias + Clear Bra
Old May 9, 2004 | 11:04 AM
minihune's Avatar
minihune
ftbt,
Thanks for the link. It shows the H-sport bar has a bend to allow for an aftermarket intake box (not sure which ones would fit perfectly) and for the stock ECU cover which tends to hit most strut braces. There are pictures of it installed on a MINI. Definitely need to drill holes. Oops. Not like the other strut braces what use the existing nuts.
H-sport strut brace mount close up and camber plate
_________________
Aloha Hawaii
Old May 9, 2004 | 02:26 PM
ScottinBend's Avatar
ScottinBend
>>I have the BMP struct brace that uses the bolts form the upper struct as mounting points. Hence, no additional drilling. All the struct braces I've seen use the same mounting spots. :smile:
Dave.......remember "BLING BLING" LOL
How did UniChip finally get your chip installed with the strut brace? Have any pics?
Scott
Old May 9, 2004 | 02:48 PM
dcsmd007's Avatar
dcsmd007
As seen in the picture, the Unichip module is under the driver's vent. However the connector portion of the unit is inside the air box under Alta filter instead of sitting on top of the fuse box. I like that better since it's totally out of the sight.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
