R50/53 No speedomer back lights, no tach, no connection to diagnotsics
Old Aug 11, 2013 | 10:28 AM
isu grape's Avatar
isu grape
2002 Mini Cooper, base model, automatic transmission
Hoping that someone on forum can point me in right direction to fix speedometer back lights and tachometer issues
Current Symptoms / issues:
· No Speedometer back lights (fuel gauge, mileage, seatbelt lights all function)
· Tachometer (fixed at 1000), lights and engine display lights on tach do not function
· Dash light dimmer switch has never seemed to work properly
· Brightness of clock varies and is never really bright.
· No power to fuse 5
· Volts from Instrument Control Cluster only sending 5 volts to tach
· No communication with diagnostic buss
· Stereo, A/C, windows, locks, and heated seats, wipers, cruise, etc all function properly
Lights on speedo went out and Tach just suddenly stopped working. At the same time:
· Battery kept discharging
· Local shop could not find source of drain / short
o Some connectors showed signs of corrosion – fixed and cleaned
Warranty / Recall & Work Performed:
· Electronic power steering pump and fan were determined to be the issue of battery drain. Replaced by mini dealer under recently announced warranty recall
· New battery installed
· New BCU installed
The BMW repair shop technician thinks there is a short someone in system causing these issues, possibly another blown control module. Advice anyone?
surfblue
Oct 24, 2018 01:20 AM
Dec 23, 2015 10:36 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
nismo4life
Aug 5, 2015 08:31 AM
