R53 Left Front Popping Noise
Old Aug 8, 2013 | 06:27 PM
JoeGravelle's Avatar
JoeGravelle
I am getting a knocking/popping feeling from the left front of my car. It just started today, day 3 of my new job!
I can feel it with my feet and a little bit through the wheel. I got home, jacked the car up and checked the steering joint and made sure it was properly attached. I verified the subframe bolts are all tight and transmission mounts. The ball joints and tie rods are all securely fastened, which leads to the shocks......
I have no record or indication that the shocks have been replaced in 164k miles...but I find it rather odd that I would get this noise immediately and not slowly build up.
I know for a fact it was not there the day I put the subframe back in or since Monday, if it was related to the clutch job/subframe removal, it would have manifested immediatly after, correct?
anyone, ideas?
Old Aug 9, 2013 | 04:38 AM
RadioActiveMan's Avatar
RadioActiveMan
Does it happen when you accelerate/decelerate or over bumps?
If its when you accelerate/decelerate I say its control arm bushings? It happened on my 325i I had a few years back.
Old Aug 9, 2013 | 06:19 AM
JRhea's Avatar
JRhea
Joe
With the car on the groubd, take your wheel lug wrench and try to tighten the lugs on the front wheels. If the wheel appears to shift in the direction that your tightening then your control arm bushing is probably shot. My wheels moved about 1/2 inch when my bushings were blown out.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
kpl
Aug 11, 2015 04:52 AM
