Suspension Opinions on where to start ....
Old Aug 7, 2013 | 03:18 PM
vietnameeh's Avatar
vietnameeh
Plan on throwing on Konis and Springs on the car finally...
for the rears I have rear trailing arm bushings (2003 model trailing arm bushings), throwing on the rear sway bar and lower control arms....
I was wndering what steps I should go in first...
obviously disassembling everything will make things easier at least for the rear trailinng arm bushing.
so i figure ... once everything is of shock/spring assembly, rear bar and lower control arms I can tackle the
rear trailing arm bushing first... then the rear sway bar... then lower control arm? then put the koni and springs on?
Im going to start with doing the rear suspension first since I have so much to do for the rear... then if i finish up successfully ill tackle the fronts which look super straight forward
any advice in what order thanks!
iggi
18
Feb 9, 2026 01:00 AM
boostedhaze
Jan 2, 2018 07:26 PM
mdutton11
14
Oct 26, 2015 01:47 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
rphox2003
Aug 5, 2015 11:34 AM
