FS:: Vorshlag Camber Plates for KW Variant 2 Coilovers(NEW
Old Aug 6, 2013 | 05:43 PM
Johan's Avatar
Johan
Category: Suspension
Price: $400
Location (Region): SouthEast
Item Condition: Brand New
Easily adjust camber track side with Vorshlag's R53, r50, r52, r55, r57 and r56 camber plates. Over-sized spherical bearings are designed to withstand the rigors of street and track abuse. All components are plated for maximum corrosion resistance and long life.
In order to properly use Vorshlag camber plates, you must choose spring perches that match your strut brand and spring type. Vorshlag camber plates are designed to be compatible with 2.5”, 2.25" and 60mm “coilover” style springs, stock style springs and all strut types.
* Compatible with 2.5", 2.25" and 60 mm Coilover springs, factory springs and all struts.
* No need to change camber plates when switching from regular springs to coilovers! Some companies sell you two totally different camber plates for coilover springs and factory style springs.
* Installs with basic hand tools, no chassis modifications required.
* Plates are designed specifically for the MINI chassis.
* Camber is easily adjustable at the track from the engine compartment with simple (metric) hand tools. No need to reach inside the wheel well with a wrench!
* The spherical bearing used in the Vorshlag camber plate is the largest used in any R53 MINI camber plate. The result has much better durability and wear characteristics than the undersized bearings used in our competitors' plates.
* Provides up to -3° front camber - a huge benefit for the Mini chassis.
* There is no change in ride height from the OEM upper mounts.
* 100% CNC machined, alloy steel construction - Tough as a German Tank!
* All components plated for maximum corrosion resistance and long life.
* Engraved with Vorshlag logo, "MINI" and orientation.
* Vorshlag Upper spring perches included (see "Spring Perch" drop down option menu, below).
Camber plates were ordered with my KW Vairiant 2 Coilovers.
Cash or pay-pal, for pay-pal please add 3%. Sorry I can not hold any items for sale at a later date.
Shipping is $13 to US
Attached Thumbnails Vorshlag Camber Plates for KW Variant 2 Coilovers(NEW-camber.jpeg
Old Aug 12, 2013 | 04:11 PM
Johan's Avatar
Johan
Ttt
Old Aug 13, 2013 | 04:08 PM
Johan's Avatar
Johan
Comes with 2.5" perches, I just got off the phone with vorshlag and they advised me that parts can be ordered for approx $110 to make these camber plates fit ant type of struts including stock. PM me if you want to make an offer. Again these are brand new and never installed, they are boxed and ready to ship!
Old Aug 15, 2013 | 09:53 AM
Johan's Avatar
Johan
Sold, thanks!
Keet
Suspension
Aug 30, 2016 03:46 PM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
CooperSharp
Oct 12, 2015 09:21 AM
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:13 PM
