R50/53 What are these lights? Reading lights or ???
Old Aug 5, 2013 | 05:30 PM
Black-eyed-Purple-Mini S's Avatar
I am just wondering what these lights are?...The show orange at night when I hold my hand under them, and when I push the buttons up and down, nothing seems to happen....Can anyone here tell me what they are, and what they do? Is there suppose to be bulbs in them, as I can put my fingers in them.
Here is the pic, (they are the white buttons at the front.)
Thanks Jeffrey
Attached Thumbnails What are these lights?  Reading lights or ???-0c7a41a2-ec09-4d00-848e-b91acf0227d5_24.jpg
Old Aug 5, 2013 | 05:31 PM
JAB 67's Avatar
JAB 67
I think they are map lights.
Old Aug 5, 2013 | 05:45 PM
Braminator's Avatar
Braminator
Yup map lights.
Old Aug 5, 2013 | 06:08 PM
AlexQS's Avatar
AlexQS
The button should make a white map reading light come on.
The orange lights get brighter and dimmer as you adjust the brightness of your gauges. They are just an accent light that help you to see the center console at night.
You should also have some orange lights like that that illuminate the little cup behind the door open pull lever.
Old Aug 6, 2013 | 06:04 AM
+1 , It should have the orange color LED that matches the lights in the back and the map lights in the front, which the orange lighting comes on when you turn your headlights of parking indicator on. The map lights you have to press the button to click on and off.
Part number 63316962019.
http://www.ecstuning.com/Search/SiteSearch/63316962019/ES175353/
#2 version with the additional LEDs from 7/2004+. Also first called waterfall lighting if I remember right. And the led in the door cups also.
The bulb could be burned out on both. x 2 for both bulbs. Clips into a twist on socket that mounts on the backside.
Bulb - Priced Each
http://www.ecstuning.com/Search/SiteSearch/63217160908/ES174578/
Socket base. Part number 63258389736 Per bulb
http://www.ecstuning.com/Search/SiteSearch/63258389736/ES175023/
Old Aug 8, 2013 | 07:43 AM
uromini's Avatar
uromini
what year and model is that in?
my 03 doesn't have that?
Old Aug 8, 2013 | 08:08 AM
tremperj's Avatar
tremperj
Our 2003's are missing a lot of nicer stuff in the facelift.
Hell, we don't even have the cig lighter in the boot.
That's for 7/2004+ .
The older MINIs I believe pre 7/2004 had the clock in that location.
Yours is an 2003, so it should have the clock below.
Digital Clock Housing - Light Gray
http://www.ecstuning.com/Search/SiteSearch/62131514196/
Digital Clock Display
http://www.ecstuning.com/Search/SiteSearch/62131512950/
Old Aug 8, 2013 | 08:23 AM
You still have great options.
Pre 7/2004 MINIs have the cool looking rear euro taillight. In my opinion I like the look.
http://www.ecstuning.com/Search/SiteSearch/63210150980/ES2580923/
The clear taillights.
Clear Tail Light W/ Bulbs - Driver ( Left )
http://www.ecstuning.com/Search/SiteSearch/63216927585/
Clear Tail Light W/ Bulbs - Passneger (Right )
http://www.ecstuning.com/Search/SiteSearch/63216927586/
Old Aug 8, 2013 | 08:55 AM
uromini's Avatar
uromini
wow you're absolutely right! brain fart.
haven't driven mine in a month or so..
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
Aug 19, 2015 12:51 PM
