JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Traction control uncertainty
Old Aug 3, 2013 | 10:52 PM
R53's Avatar
R53
Hi everyone
On my ex R53 when you driving hard and changing from 1st to 2nd the engine cuts abruptly if the traction was on causing a jerk and delayed throttle response in the next gear , but if you switch traction off this went away.
On my FJCW with the controls fully off (hold DTC for 3 seconds) it's doing exactly what the R53 done with traction on. Why is it doing this?? Is it maybe faulty?
Even using dtc mode it doesn't cut the car as aggressively.
Anyone have an explanation or is it a fault?
Old Aug 3, 2013 | 11:08 PM
Btwyx's Avatar
Btwyx
With the DTC in stage 2 off, I've never felt any traction interventions, so something's wrong there.
Are you sure you've actually turned it off? If you're in DTC mode and don't hold the button for long enough it'll go back to normal mode. DTC/Stage 1 off I get "Traction" in the tach display. I'll feel brief traction interventions on an aggressive upshift, sounds like what you've experienced. In stage 2 off, the tach displays "DSC Off" and has the icon of the car and slippy road. The light on the speedo will also stay lit.
You can see if its making traction interventions as the light in the speedo flashes when it does that.
Old Aug 3, 2013 | 11:24 PM
R53's Avatar
R53
I'm very sure it's off. The triangle appears on the dial in front of me. Held on DTC for 3 seconds.
It's just strange experiencing a cut like that when you expect no interferences.
Is it anything got to do with the electronic diff that the Jcw has?
Old Aug 4, 2013 | 04:18 PM
Btwyx's Avatar
Btwyx
I'm not expecting to feel anything from the electronic diff, that should only come into play while cornering. I'm assuming your acceleration is in a straight line. I've never felt anything anyway.
Casrio
Apr 20, 2021 01:52 AM
rbarakat
Oct 3, 2015 11:08 PM
Suspension Products
Sep 10, 2015 11:46 AM
Suspension Products
Sep 3, 2015 09:41 AM
Ntety
Sep 2, 2015 08:39 PM
