R56 noise when barely on the gas?
Just as the title says; when im going about 50mph+ in 5th or 6th and I barely have my foot on the gas I hear a high pitch whining noise. Dealer says its coming from the trans but the car drives fine.
If your still under warranty then that at least helps put your mind at ease... But I would just pay close attention to it..see if it gets worse..also maybe the noise isn't even coming from the transmission... It sure wouldnt be the first time the dealer told me one thing and ended up to be totally something else!...good luck!
In my experience if you know something's wrong and you continue to drive it, they could say when it's time for repair,"why did you continue to drive it if you knew something is wrong with it?
When I told dealer that I knew I needed a timing chain components replaced, they told me to not drive it! Imagine that I did drive it after telling them that and I drove it, chain slips off cams and I expect them to cover it under warranty? I think not!
If something does breaks though ill take it to the dealer I bought it from cause they dont know I took it to the mini dealer so warranty wont know ****
except that its all stored in your key fob. I wouldn't worry too much. If I take it to the dealer and they can't figure out what is wrong, that's not my fault. You made a good faith effort to get it fixed.
its super easy to do yourself, 2 hex bolts on the side of the tranny, all you need is one of those hand pumps that screw on the gear oil bottles. a good practice is to remove the top bolt first and then the bottom, because if you remove the bottom bolt first and realize you cant get the top one out, guess what, you cant refill the tranny and the old oil just drained out the bottom one.
I noticed a slight rattle noise when slightly pressing the gas pedal and figured it was some noise from the direct injection fuel injector. When injecting directly into the combustion chamber the injector needs to be able to close tight enough to not allow combustion gasses to flow back into the injector.
Supertractor3
Apr 7, 2017 11:16 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
