JCW Brake pad options?
Old Jul 30, 2013 | 06:12 PM
5thscaleracer's Avatar
5thscaleracer
Brake pad options?
Aside from factory pads is there anything out there that can offer less brake dust and improved bite?
Any info is greatly appreciated.
Old Jul 30, 2013 | 06:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
that's easy EBC Redstuff pads perfect for the street car.
Old Jul 30, 2013 | 06:34 PM
Braminator's Avatar
Braminator
You can chose and read up on these
http://ebcbrakes.com/product/redstuff-brake-pads/
http://www.hawkperformance.com/performance/hps.php
Old Jul 30, 2013 | 06:39 PM
5thscaleracer
Cool thanks for the tip!
Old Jul 30, 2013 | 06:47 PM
5thscaleracer
Next question are all mini brake pads the same? I have a set of ferodo pads from my 07 r56.
I am only assuming this because on way's site it says all minis
**** edit ****
07 mcs pads do not fit unless equipped with the non brembo JCW brake kit.
34 11 6 778 320 jcw non brembo which fits jcw r60 2013 prod date 3/13
Old Jul 30, 2013 | 06:50 PM
WayMotorWorks
Vendor
NO, you have to select your model on the left side of the page.
the page your talking about just says we carry EBC for All MINIs
Old Jul 30, 2013 | 06:53 PM
5thscaleracer
I c ok thanks
Old Aug 16, 2013 | 07:32 AM
5thscaleracer
Just to update everyone..
I ended up doing some research and found that my 2013 jcw shares the same brake pads as a 2012 MCS.
So I ended up using akebono Euro pads, part number eur1204 $65.00.
It's been 3 days, no dust!
Initial bite its not as grabby as oem pads but has a better follow through. Oe pads felt like it bites hard at first then begins to fade. These bite and progressively begins to bite more.
I am a happy camper now...
Old Aug 16, 2013 | 08:04 AM
v10climber's Avatar
v10climber
The rears would be the same but the fronts are different. The pad shape is quite different.
Old Aug 16, 2013 | 08:12 AM
5thscaleracer
Really?
I ordered and installed a set yesterday afternoon.
The rears I have not looked into it yet because my local supplier does not have the matching akebono pads yet.
The MCS must have the JCW TRW non brembo upgraded brakes. There are three available brake pads.
My 07 MCS w/n14 the pads were shaped differently non brembo/non JCW.
Old Aug 16, 2013 | 08:29 AM
Yea, the JCW 4 piston brakes in the front look like this.
This is the caliper 4 piston JCW Brembo - Front Left
http://www.ecstuning.com/Search/SiteSearch/34106856651/
Fits These:
http://www.ecstuning.com/Search/SiteSearch/34116789157/ES253346/
Or
EBC Reds
http://www.ecstuning.com/Search/SiteSearch/DP31854C/
The single piston JCW brakes (TRW) for the Gen 2 MINI share the same front pads as Cooper S. Not too many people have the Single piston JCW brakes on there Gen 2 MINI. Same caliper as the R56 Cooper S , just painted Red and JCW logo.
http://www.ecstuning.com/Search/SiteSearch/34116778320/ES59944/
And here is the Akebono set front an rear.
http://www.ecstuning.com/Search/SiteSearch/34116778320KT2/ES2588100/
Hope that helps with the pictures.
Old Aug 16, 2013 | 08:32 AM
Braminator's Avatar
Braminator
ECS, can you post caliper pictures? That might really help some.
Old Aug 16, 2013 | 08:43 AM
Sure Bram added more pics. Thanks for letting me know.
Old Aug 16, 2013 | 09:07 AM
Braminator's Avatar
Braminator
Im sure that will help some now understand the differences of what they might have on their MINI. Thx
Old Aug 18, 2013 | 07:35 AM
preme123's Avatar
preme123
Just to clarify, the front brake pads of a mini Countryman S ALL4, is the same as the ones in the mini cooper S R56? Are they exchangeable?
EBC reds/yellows front brake pads for R56S would fit CTMS ALL4?? is this true?
Old Aug 18, 2013 | 07:43 AM
5thscaleracer
Not exactly
R56 has 3 brake options
Stock cooper S r56 pads will not fit the r60
Cooper S or jcw with TRW calipers which is an upgrade option for the r56S but stock on JCW, That fits the R60
Cooper S r56 or jcw with brembo 4piston upgrade will not fit the R60.
Only the "trw" brand calipers share the same brake pad.
Old Jan 30, 2017 | 12:24 PM
Lex2008's Avatar
Lex2008
How about VAICO pads sold via ECS "Tuning"? Anyone install these?
https://www.ecstuning.com/b-vaico-pa...116778320~vai/
Old Feb 8, 2017 | 05:58 AM
I had them, they are very close to the OEM pad in performance, maybe a little less dust. Justa lower cost option for a stock replacement.
Old Feb 8, 2017 | 07:55 AM
Lex2008's Avatar
Lex2008
You're so cheap bro! Joking. I appreciate the info.
I'm going with EBC Redstuff's to get a break on the dust accumulation. I know EBC sells rotors but they are way pricey. I assume the EBCs are compatible with any rotor yes? I usually match pad and rotor by brand since I know those combos are proven.
Old May 11, 2018 | 01:55 PM
TerminalVelocity's Avatar
TerminalVelocity
Akebono euro's for JCW Paceman
Fits These:
Or
EBC Reds
Sorry for the dead post resurrection but I'm looking for Akebono Euro's to fit my '13 Paceman JCW (with TRW front brakes) and the links provided here show they don't fit when checking on the ECS website. If anyone can confirm what part number fits both front and backs I'd greatly appreciate it. This post is the closest thing I've found online that even goes into detail on the brake combo for the paceman JCW.
Old May 11, 2018 | 02:06 PM
Hello,
They take the same pad here: Front Euro1204 , rears Euro1554
https://www.ecstuning.com/Mini-2013-.../Braking/Pads/
Ones above are talking about the 4 pot vs the single pot JCW which is also similar to the TRW gen 2 Cooper S.
Old May 11, 2018 | 02:11 PM
TerminalVelocity
Gotcha thanks
Hello,
Ya after re-reading your post and looking on the ECS site I realized I was filling out the vehicle profile as my own (JCW Paceman) when I should have been verifying that they fit a 2013 Cooper S (R56). The website just doesn't list them as fitting a JCW Paceman. Sadly the Paceman/Countryman didn't get the 4 pot Brembo's. Mine are TRW's painted red and the standard R56 rears also painted red. Thanks again for the help!
Old May 11, 2018 | 02:14 PM
Yep, just select your vehicle on our site which i linked above. We will always call out if there is a weird or "only set up" on our site.
Old May 14, 2018 | 08:32 AM
Subw00er's Avatar
Subw00er
What do you guys think of the redstuff after having them a while? Any brake noise, less dust and improved performance/initial bite?
Old May 23, 2018 | 11:44 AM
Had redstuff and hawk HPs, I liked them both. Great bite. If you get the more aggressive pads they will make more noise as you work up the ladder. Dust on both was far less them OEM pads.
