Flat tire sound when turning
Old Jul 29, 2013 | 03:53 PM
RYOAK5150's Avatar
RYOAK5150
Another issue
This sounds CV related, but thought Id double check.
The sound resembles that of a flat tire when going around curves, or turning at higher speeds. Only on the front driver side. I checked the CV boots and saw no leaking. Wheel bearings tend to make a grinding sound more than anything, but I havent ruled that out yet. Tires are fairly new.
Suggestions? What should I look for?
Old Jul 29, 2013 | 04:17 PM
danjreed's Avatar
danjreed
Originally Posted by RYOAK5150
Another issue
Typically a bad CV causes a rapid clicking sound under power on corners (outer) or a harsh vibration under power (inner).
I'd first rotate the tires and see if the noise moves with the tire or stays at that corner before guessing any further.
Look at the tires for bulges (slipped belts).. Or road damage (bubbles, gashes.. Etc..).
Check for debris stuck between the rotors and the dust shield as well.
Old Jul 29, 2013 | 04:20 PM
RYOAK5150's Avatar
RYOAK5150
Its a smooth ride and no clicking. Just a thud, like a flat tire.
I'll rotate the tires and see if that fixes it. I cant see any wrong with the tire itself. My other thought was the rotor itself. The car is new to us, so Im still compiling a list of issues and working through them.
Thanks for the response.
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
