Top Engine Mount - can I drive around with a broken one?
Old Jul 26, 2013 | 08:36 AM
Hochspannung's Avatar
Hochspannung
My top engine mount sprayed all the oil out of it last night.
Can I drive with it broken?
Old Jul 26, 2013 | 08:51 AM
You can in the short time , but you will get the clunk noise when shifting sometimes. Clean up the oil as much as you can because it does stain on the frame paint when it leaks out. I still have little the stain mark on mine.
Here is the part: Part number 22116778610 in case you need it.
http://www.ecstuning.com/Search/SiteSearch/22116778610/
Old Jul 26, 2013 | 10:21 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You can drive around with it broken and the engine is not going to fall out. Longterm it will do damage to other mounts and possibly the clutch, but for the short time till you can get one it's not going to fall apart.
Old Jul 26, 2013 | 10:40 AM
ZippyNH's Avatar
ZippyNH
You will be fine for a few hundred miles.....
Heck some folks might go a few years and not realize it.....
You will feel you shifts and cruise control disconnects are more harsh....and maybe hear a thunk....
Old Jul 26, 2013 | 06:03 PM
Hochspannung
Ok sounds good. I have a reduction pulley sitting on my dresser. Guess ill get that all done together when I have some cash.
Old Jul 26, 2013 | 06:10 PM
rennwerkes's Avatar
rennwerkes
Make sure you have a new torx screw.
Mine snapped when I unscrewed it because it was corroded from the hydraulic oil leaking onto it.
Old Jul 26, 2013 | 06:14 PM
Hochspannung
Torx screw for what ?
Old Jul 26, 2013 | 06:19 PM
rennwerkes's Avatar
rennwerkes
It screws into the bottom of the mount.
Old Jul 26, 2013 | 07:14 PM
Cease's Avatar
Cease
Pretty easy DIY, specially if you are installing a pulley because the motor has to be lifted to fit the puller in.
I got the mount from Pelican Parts (vendor) for like 79 bucks. Check your bottom mount too, may be worth replacing it while you're at it.
Old Jul 26, 2013 | 07:21 PM
Hochspannung
I can't do it myself. I have no space to work. Going to have to have a shop do it.
Old Jul 26, 2013 | 07:31 PM
Cease's Avatar
Cease
Bummer.
If you're going to have someone install the 15% it shouldn't take anymore than an additional 15 mins to get the mount in. Check to see if there is any Mini club around you, I've installed a few pulleys for local Mini club members for a case of beer
09R56
Nov 16, 2022 10:49 AM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
silence2-38554
Nov 12, 2015 09:39 AM
dchang0
Aug 10, 2015 03:37 PM
