Suspension R53/R52 struts/shocks question
Old Jul 24, 2013 | 09:59 PM
Noir2005's Avatar
Noir2005
So, I'm looking to change out the struts and shocks on the wife's R53. I have a few sets in mind, however, some sites say for R52 only, some say depending on power output, and some don't say anythingnregardless of part number, or vehicle specifics. I can see the rear shocks being a factor due to more weight in the back, and suspension geometry to fit canvas top, or the S having a sport suspension. Long story short, is there any differences, and if so, what is and isn't compatible with one another?
Old Jul 25, 2013 | 04:14 AM
GreekDrifter91's Avatar
GreekDrifter91
there is no diffrence between the r50, r53, and r52. just just spring stiffness.
try the vendors on this site. they are quick, knowledgeable, and helpful.
try waymotorworks.com , helix13.com , germanautoparts.com , minicarparts.net .... look around the site you will see the vendors.
Old Jul 25, 2013 | 01:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Most cost effective and best solution is just to go with the Koni FSD shocks as a replacement. Technically there are several different versions of the stock shocks, but the difference is very minor if you could even tell.
Old Jul 26, 2013 | 10:21 AM
IQRaceworks's Avatar
IQRaceworks
I have FSD's on mine....they were a HUGE improvement over the stock shocks.
Old Jul 26, 2013 | 06:32 PM
Noir2005's Avatar
Noir2005
Good info, narrows down the selection! Does anybody have any input on Bilstein touring class shocks? I'll see if i can talk my wife into the fsd, but if not, my backup plan would be the bilsteins.
Old Aug 5, 2013 | 07:11 PM
Noir2005's Avatar
Noir2005
also, does Koni warrenty the shock tube for life, or do they not cover normal wear and tear? I know bushings, washers, and mounts are not, but since our o.e.m. ones go out in 40k, I'd hate to spend all that money on shocks, only to last another 40-60k.
Old Aug 5, 2013 | 07:56 PM
GreekDrifter91
yes koni has a lifetime warranty
Old Aug 5, 2013 | 10:15 PM
PrplPplEtr's Avatar
PrplPplEtr
+1 for the FSD, just put them on and it's like night and day. still sharp and aggressive, but no longer bone-jarring. it rides like a real car now.
Old Aug 16, 2013 | 04:38 PM
DanSeals's Avatar
DanSeals
+2 for the FSD's, 113000 hard earned miles and still going strong!
Definitely ride better than the OEM struts.
Old Aug 17, 2013 | 07:14 AM
cristo's Avatar
cristo
Alliance Member
Did you know that there are actually 15* different R50/52/53 shocks (21* if you count the European MINI One model with standard suspension).
four levels of stiffness:
Standard, (One)
Sport Suspension (One, Cooper)
Sport Suspension Plus (Cooper, Cooper S)
JCW
Two more levels of stiffness:
Pre-5/2003 production (thicker fluid)
Post-5/2003 production (thinner fluid)
but ... I think there's only one fluid variant for the JCW shocks
and three unique locations:
Front Right
Front Left
Rear
* actually 21 or 27 if you count the early front struts from before 3/2002
Last edited by cristo; Aug 17, 2013 at 08:31 AM. Reason: correction - see next post
Old Aug 17, 2013 | 08:29 AM
cristo's Avatar
cristo
Alliance Member
Oh, I forgot the early front struts before 3/2002 in 3 ranges.
That makes 6 more.
Old Oct 5, 2013 | 08:34 PM
bigsteverealtor's Avatar
bigsteverealtor
I know that Koni and maybe Bilsteins and the norm but has anyone got any input on Monroe Spectrums??
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
