Suspension Is it possible to get the tires to go past the fenders a little bit
Old Jul 24, 2013 | 02:02 PM
zachwalker94's Avatar
zachwalker94
I own an 05 Mini Cooper s r53. And I was wondering if it was possible to get the tires to go past the fenders a little bit. And if so, how much would it cost and where could I get it done at??
Old Jul 24, 2013 | 02:22 PM
Braminator's Avatar
Braminator
Why? What wheels are you using?
Old Jul 24, 2013 | 02:29 PM
grgramps's Avatar
grgramps
I see lots of kids in pickup trucks doing that. I suppose it depends on what you want it to look like. You can do anything for the right money.
Old Jul 24, 2013 | 02:34 PM
zachwalker94
I'm sure what wheels I'm using, I was just wondering if it was possible. Because I have this image in my head that I think would look great on a Mini Cooper. I just need to know if it's possible to have the tires go past the fenders a little bit.
Old Jul 24, 2013 | 03:17 PM
irieman's Avatar
irieman
Check out the "will it fit" thread at motoringunderground.com (link below). Plenty of knowledgeable folks over there on this very topic.
http://www.motoringunderground.com/f...ead.php?t=1029
Old Jul 24, 2013 | 04:35 PM
rkw's Avatar
rkw
How much "poke" (that's the common term) are you looking for? You can move out the wheels up to about an inch using spacers: http://www.turnermotorsport.com/p-16...cers-pair.aspx. Otherwise do it by choosing a wheel with low offset.
Old Jul 24, 2013 | 04:59 PM
zachwalker94
Maybe like an inch or an inch and a half of "poke" would that be doable?? And if so how much would it cost and where would I get it done at? Lol
Old Jul 24, 2013 | 05:24 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Rather than "poke", can you say "score"? That's what your fender extensions will do to your tires if you go over a bump or hit a pot-hole. Also, adding wheel spacers always tend to cause undo strain on hubs. If you do, you'll need longer lug bolts and I strongly suggest you get the best you can buy because of that added stress.
Old Jul 24, 2013 | 06:39 PM
zachwalker94
Ohhhhhhh, ok!
Old Jul 24, 2013 | 07:05 PM
mini coop's Avatar
mini coop
Yes. This by decreasing the offset of your wheels or by buying wheels spacers to move the wheels out more.
Old Jul 24, 2013 | 07:52 PM
Braminator's Avatar
Braminator
Check these 2 threads out as I am sure they are to your likings.
https://www.northamericanmotoring.co...de-wheels.html
https://www.northamericanmotoring.co...post-pics.html
Old Jul 25, 2013 | 06:15 AM
v10climber's Avatar
v10climber
It's possible but you'll have to make a lot of compromises in ride comfort/handling.
Old Jul 25, 2013 | 08:28 AM
MiniWii's Avatar
MiniWii
Here's how they do it!. I was in big into fitment when I owned my subaru. Like others have said, you can either use spacers or go with a low offset wheel. Whenever you go past the fender you'll need to run lots of neg camber. Also to minimize tire contact with fender, you'll also run a stretched tire size.
http://www.stancenation.com/wp-conte...012/09/144.jpg
Look at this picture for reference what I'm talking about, you can see it in the rear wheel.
Old Sep 13, 2013 | 07:37 AM
t-c-b's Avatar
t-c-b
how bizarre - it would just look odd in my view
Old Sep 13, 2013 | 07:52 AM
pghJohn1010's Avatar
pghJohn1010
Hub strain will increase the same regardless of how you get the tires further out.
I'm guessing I'm just showing my age, but it's for good reason doing that would not be legal in this state. That part of the moving vehicle should not easily be able to contact vehicles, immovable objects and pedestrians. Of course, you don't want any part to do so.
Of course, that does not qualify as an answer to your question.
Old Sep 13, 2013 | 08:00 AM
ZippyNH's Avatar
ZippyNH
That is why trucks MUST have those fender flairs screwed onto them when bigger offroad tires are used...
You can throw rocks, rain, sand, etc over a wide area with the tires poking out beyond the wheel wells.....
Many places have fines/tickets if you have not added fender flairs to match the wider rims....
Old Sep 13, 2013 | 02:49 PM
mini coop's Avatar
mini coop
A 30mm offset will perfectly align the tire/wheel combo to the edge of the flare. This with no tire stretch or poke. I don't see where altering camber is needed with this fitment. It does sit aggressively though.
Kimolaoha
Dec 5, 2020 09:32 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
L3Mix
Aug 26, 2015 07:00 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
Emnotek
Aug 13, 2015 05:47 PM
