R52 How is much is the r52 different?
Old Jul 22, 2013 | 05:30 PM
doseddies's Avatar
doseddies
Ok so I have a 2008 Cabrio. Every time I look at CAI setups I'm steered to turbo parts. Should I assume it is and 07, 06 or what? I know they kept the first gen until 09, but didn't anything change? Are any parts unique to Cabrio's? Or are they first Gens with a different top only? So to speak.
Old Jul 22, 2013 | 06:08 PM
Braminator's Avatar
Braminator
What's the build date of your cabrio? Then we can help you.
Old Jul 22, 2013 | 06:47 PM
doseddies's Avatar
doseddies
Old Jul 22, 2013 | 06:48 PM
doseddies's Avatar
doseddies
It shows 07/08.
Old Jul 22, 2013 | 06:50 PM
doseddies's Avatar
doseddies
07/08 is the build date.
Old Jul 22, 2013 | 07:05 PM
doseddies's Avatar
doseddies
Sorry about that, I was on my phone. I thought it didn't post.
Old Jul 23, 2013 | 12:14 AM
rkw's Avatar
rkw
Yes, the 1st gen convertible and hardtop use the same engine and suspension parts. Look for parts that fit a 2006 hardtop R53 (S) or R50 (non-S). Or simply look up parts for a 2006 R52. Many vendors mislabel parts for the '07-'08 convertible because of the confusion with '07-'08 hardtop.
Old Jul 23, 2013 | 05:35 AM
ZippyNH's Avatar
ZippyNH
Yup...most any 2006 r50 hardtop (non s) or r53 hardtop (s) will fit....
Just get the one that matches up with your motor...and plug it in....(to the parts meanu)....and enjoy the parts!!
Just pay attention to the tranny....with some items under the hood, auto/ manual can make a bit of a difference fittment wise....
Old Jul 23, 2013 | 06:42 AM
Yep,
On the Convertible Cooper ( Non S ) with the intakes because of the design on the transmission, the stock OEM transmission air box has a triangle design for the manual and square design for the automatics.
When checking out the 2005-2008 Convertible , make sure its a Gen 1 R52 Chassis.
Here is a picture for reference on the Cooper Convertible (non s).
R52 MINI Cooper Convertible (non S) with manual transmission.
R52 MINI Cooper Convertible with automatic.
R52 MINI Cooper Convertible S
Old Jan 23, 2014 | 12:55 PM
krazyskwerelette's Avatar
krazyskwerelette
Some parts for the r53 wont work on the r52 due to the engine being an inch higher
Old Jan 24, 2014 | 09:24 AM
bugeye1031's Avatar
bugeye1031
Moderator
Thanks for noting that!
Old Jan 25, 2014 | 10:59 PM
joylove's Avatar
joylove
*2.54cm
Old Jan 25, 2014 | 11:27 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
The R52 also has a good bit of under body bracing not found on the R50/53 hard tops.So if you are in the market for some suspension related stuff, keep in mind you may have a few extra bolts/parts to remove.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
Sep 30, 2015 10:58 AM
