Replacing Power Steering Hoses DIY?
Old Jul 20, 2013 | 01:29 PM
jennster's Avatar
jennster
I was hoping to replace the hoses myself. I did manage to find a tutorial on disconnecting them topside from the PS Pump but nothing for underneath. Any suggestions here?
Old Jul 20, 2013 | 01:44 PM
azkid's Avatar
azkid
I used this http://www.billswebspace.com/MiniR53PSPFanDuctDIY.htm when I rebuit my power steering pump but it shows you how to get to the lines underneath. FYI I installed worm clamps on my hoses near the reservoir and that solved my leaking problem.
Old Jul 20, 2013 | 04:21 PM
baznight's Avatar
baznight
If your trying to replace both lines from the reservoir then its pretty easy. Just release the 10mm nut on the carrier for the reservoir. Use a 22m socket or ratching wrench for the like going to the rack and just cut out the lower band for the other line at the pump. Then pull both lines up thru the engine bay still on the reservoir. Install your new lines onto the reservoir on your bench. Then reinstall. I still think you will have to lift the vehicle partially though as the lower clamp on the pump is hard to get to.
Old Jul 21, 2013 | 03:24 PM
jennster's Avatar
jennster
Do you of anywhere that has illustrations of this process. This doesn't sound incredibly difficult and yes, I'm just trying to replace the two from the reservoir, not the pressure hose.
Etrain
16
Aug 5, 2024 04:37 AM
Kimolaoha
Jul 5, 2023 01:04 PM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
