Suspension Corner Balancing
Old Jul 19, 2013 | 04:39 AM
jscornavacca's Avatar
jscornavacca
Corner Balancing
A number of like-minded autocrossers were discussing corner balancing and front to back weight ratios after a local BMW event (none, except for me, were MINI drivers) and I had no idea what is the ideal weight ration for a MCS 2011.
I know a number of you have had your cars corner balanced. Can you share your numbers with us? Can anyone recommend someone in the Boston area to get this done? What improvement did you notice?
Thanks in advance!
-Jeff
Old Jul 19, 2013 | 07:22 AM
v10climber's Avatar
v10climber
We haven't gotten ours corner balanced yet. It took us a year to figure out alignment/ride heights we're happy with. It did get put on scales recently but they weren't leveled so corner weights weren't accurate. Corner balancing is next on the list. Just haven't had the time to head to a friend's house with scales and a lift to mess with it. Typically all a corner balance is going to do is make your left and right turns behave more consistently. I'm not sure you'll notice a huge difference but the difference is there.
Old Jul 19, 2013 | 07:34 AM
bean's Avatar
bean
Getting the cross weights even is all you can hope to accomplish. front/rear weight is a problem which we just have to accept. at a high level of competition, the difference will be noticeable. for an average, out to have some fun, guy, not so much. probably more improvement to be made in the driver, for most of us.
Old Jul 19, 2013 | 07:53 AM
jscornavacca
Very true. At this point, my car is way better than I am!
Old Jul 19, 2013 | 08:23 AM
countryboyshane's Avatar
countryboyshane
Your cross-weight should be 50% regardless of the car. Keep in mind that's with you in it and full tank of gas. If you don't have a boatload of experience on the Auto-X course or track, don't worry about it now. It's when you really have a feel for your car and need that extra bit of handling edge to gain those couple tenths that you need it.
Old Jul 19, 2013 | 10:29 PM
Btwyx's Avatar
Btwyx
I got Tristan corner weighted, more for interest than anything, he is our autocross car though. The results were (without driver):
LF 762 759 RF
LR 439 467 RR
That's 49.4% cross
With a driver, the cross does't actually change.
Is there anything you can do to adjust this if you're in stock class?
Old Jul 21, 2013 | 01:39 PM
jscornavacca
Thanks for the numbers!
Suspension-wise, I don't believe there is (but others here know way more than I do). Coilovers are the adjustment mechanism and they will put you in STX.
Old Jul 22, 2013 | 04:57 AM
v10climber's Avatar
v10climber
Nope nothing you can do in stock class to shift weight around except a lightweight catback exhaust.
krohm
Sep 28, 2015 12:16 PM
rt808
Sep 25, 2015 01:59 PM
minimofo
Sep 20, 2015 05:17 PM
MINI-Madness
Sep 11, 2015 11:31 AM
Suspension Products
Sep 2, 2015 10:32 AM
