R50/53 Spark Plug Wire R&R Help
I was reading somewhere that the "flap" on the spark plug boots are supposed to form a seal to the valve cover when connected to the spark plug.
However, mine allow for a small (about 1/4") gap between the valve cover and the flap.
When I install the plug connectors all have a nice "snap" or "click" when engaging the spark plug.
I'm using stock wires and NGK plugs.
Am I missing something here?
Thanks!
Thanks!
They should set flush. Push down all the way on the top of the boot to make sure.
What NGK plugs are you running ? Stock.
MINI plug wires.
http://www.ecstuning.com/Search/SiteSearch/12127513032/
MINI plug wires.
I'm using the factory type NGK's and have measured them again the originals and both are the same height.
I wonder if I'm doing something obviously stupid???
But as I said before, all connectors snap in nicely.
Do I push down even more after that???
eliseo1981
May 10, 2016 05:19 AM
Sep 2, 2015 09:05 AM
