Here are a list of problems i have run in to, lets compare.
Old Jul 14, 2013 | 06:50 PM
tweiss8's Avatar
tweiss8
I have owned my car (04 mcs) since 77k, now it has 115k.
Mods: nvidia exhaust
Alta 15% pulley
Msd ignition
Alta intake.
The purpose of this post is, I want to compare my problem list over the last two years to see where I sit in terms of problems.
Ecu software reload at 78k
Valve cover gasket at 82k
Oil pan gasket at 82k 92k 113k
Steering input shaft at 100k
Window regulator @ 80k
Lca bushings at 100k
Drivers seat lift assembly ( seat got stuck in the highest position) @113k
Interior door latch cable I believe to be stretched out ( I can open the door from outside fine, not inside, and it does not lift the lock on the first pull). Today at 115k
Is this abnormal, average?
I once upon a time, was upset at my miata because it needed a clutch slave cylinder @ 160k. That's it for being "down" everything just always seemed to work. I understand its not fair to compare the two, but I feel that once a month I have an oddball issue with this cooper. So, what do yours guys have for a list?
Old Jul 14, 2013 | 09:48 PM
OV_MINI's Avatar
OV_MINI
tweiss8,
We've an '06 MC that we've had since 7.5k miles and it now has 65k (after six years). Have changed one of two LCA's under warranty; twice replaced cracked thermostat housing (once under warranty); replaced left front antilock braking sensor; and replaced crankshaft position sensor o-ring that was allowing engine oil to seep out on engine block. These are the only items outside of normal maintenance (i.e., serpentine belt, battery, etc).
Did you get any maintenance records for first 77k? Any ideas how the car was treated/maintained for that period of time before you picked it up?
Old Jul 16, 2013 | 06:45 AM
Wookie's Avatar
Wookie
tweiss8,
I've had my '05 MCS since new. Took delivery 12/04 with 9 miles on it, currently has about 80k.
LCA bushings were done at 70k, valve cover gasket at 45k and 72k, crank pulley at 60k, rear caliper replaced at 72k. Had a slight drip from the oil pan gasket since about 40k, but nothing worth the cost to fix.
Biggest issue now is the PS pump failed 5/31 and have been waiting since then for MINI to send the dealer the replacement parts to have it fixed under warranty.
Not sure why you had to reload the ECU software, that's a new one unless the PO had some weird tune on it. The 3x oil pan gasket seems excessive, maybe misaligned when installed? Or maybe not even leaking - the main seal is known to weep just above the oil pan area.
Old Jul 16, 2013 | 09:07 AM
tweiss8's Avatar
tweiss8
I had the software reloaded by the dealership to fix a malfunction that made the EML light pop up and go into limp mode. The loaded it for free and hasn't been back since then.
Kimolaoha
Jul 5, 2023 01:04 PM
miniuy
Oct 7, 2016 12:09 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
FrostyFox
Aug 12, 2015 02:33 PM
