02" AC Controller dead dash lights not working help
Old Jul 13, 2013 | 11:27 PM
davidvizion's Avatar
davidvizion
ok just got my power steering pump and fan replaced on Thursday and I have another problem please help. I been driving the mini every day sense I got the power steering done and today I don't work so I had to move the mini. The problem is that the AC Control will not come on its dead also my blinkers work but they don't blink on the dash, the sunroof was open a little bit and I tried to close it and nothing but tuning the car on and off and then it got some power and I closed it but later I tired to open it and no power also the dash lights will not come on. Some times the car takes awhile to start. Please help thanks
Old Jul 14, 2013 | 05:50 AM
baznight's Avatar
baznight
Did it happen to rain while the sunroof was open?
Old Jul 14, 2013 | 08:15 AM
ZippyNH's Avatar
ZippyNH
"Takes a while to start" .....
That and other electrical oddities sometimes means the battery is on the way out...
The car is after all... One big computer...so low voltage from a weak battery (from not driving or from simply a bad cell or old age) can cause issues....
Simplest thing...trade the battery with another car for a couple minutes...see if it cranks and other issues go away....a check with a voltmeter, etc can be done too...as could a battery load test.
Old Jul 14, 2013 | 08:16 AM
davidvizion
No it was closed I this stared to happen a day after the rain we had. Also just found a new problem the volume on the steering wheel won't work or to change the channels. On the radio itself works just not on the steering wheel
Old Jul 14, 2013 | 08:18 AM
davidvizion
Originally Posted by ZippyNH
"Takes a while to start" ..... That and other electrical oddities sometimes means the battery is on the way out... The car is after all... One big computer...so low voltage from a weak battery (from not driving or from simply a bad cell or old age) can cause issues.... Simplest thing...trade the battery with another car for a couple minutes...see if it cranks and other issues go away....a check with a voltmeter, etc can be done too...as could a battery load test.
That's what ill do today ill take it to get tested. Is this a know problem with low battery life on the mini's? thanks
Old Jul 14, 2013 | 11:11 AM
davidvizion
Ok just got the battery test and they said it was good, they said it was 94% charged
Old Jul 14, 2013 | 11:54 AM
ZippyNH's Avatar
ZippyNH
The weak battery was the simple/cheap thing...lots of odd issues just as it dies....
Those question about water was due to the fact the BCM, located in the pax side foot well, can get wet...and issues. So look for moisture....
Next...
Check the battery connections...clean and tight ...and the main ground by the top engine mount.
Old Jul 14, 2013 | 12:11 PM
baznight's Avatar
baznight
I would check the drivers carpet for moisture. You will have to pull back the plastic kick panel to check the foam under the carpet. The main connector for your dash harness is there mounted to lower side of the fuse panel.
Old Jul 14, 2013 | 06:03 PM
davidvizion
did that also check the fuse one was bad but not the issue it was the still doing the same thing, the battery is good and no water or moisture anywhere around
the BCM, what els can it be?
Old Jul 14, 2013 | 07:50 PM
baznight's Avatar
baznight
The bcm is on the passenger side kick panel. The connector I was referring to is on the drivers side kick panel. It clips on the lower side of the fuse panel. Just open the connection and look to make sure there isn't any corrosion. You might not feel the moisture but you need to disconnect the connections and actually look at the pins and make sure there are growing the dreaded green garden.
Old Jul 14, 2013 | 08:44 PM
davidvizion
Ok ill do it, and if there is what will be the solution , thanks
Old Jul 15, 2013 | 04:15 AM
baznight's Avatar
baznight
Find leak and fix. Most likely drivers sunroof drain if corrosion is found here. Then clean/replace corroded pins and wiring as necessary.
Old Sep 15, 2013 | 12:57 AM
zapotek's Avatar
zapotek
Was this issue resolved? I have the same problem. If i disconnect the battery for a moment it solves the problem for a few days, but it always returns. Have seen no signs of any leaks.
Old Sep 15, 2013 | 08:19 AM
davidvizion
let me ask you this do you have the iPod/aux adapter conn to you radio, and I did fix the problem $300 after
Old Sep 16, 2013 | 03:24 AM
zapotek's Avatar
zapotek
I actually have a 3rd party iphone/aux docking device connected, will try to disconnect it and see if it solves the problem.
Old Sep 16, 2013 | 08:11 AM
davidvizion
ok well i payed my mechanic over $300 and he couldn't fix it so one day everything just start to work I was cool, but i notice when i plugged in my aux cable like yours from a 3rd party the all the my stuff stop working so I unplugged the whole thing off and sense then no issues so hope that helps let me know thanks
Old Oct 21, 2013 | 05:41 AM
zapotek's Avatar
zapotek
Removing the 3rd party iphone device seems to have solved the problem Thank you!
wkp1219
Nov 13, 2015 07:52 AM
minicoclub
Aug 25, 2015 09:07 AM
skippermini
Aug 13, 2015 06:13 AM
nismo4life
Aug 5, 2015 08:31 AM
