Crank sensor o-ring replacement
Old Jul 13, 2013 | 09:11 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Anyone had this o-ring leaking on his R53?
Old Jul 13, 2013 | 09:16 PM
baznight's Avatar
baznight
Its a pretty common leak. Easy fix if its on a lift.
Old Jul 13, 2013 | 11:26 PM
Eric_Rowland's Avatar
Eric_Rowland
Yep, happened to me. See this thread. Mine is the last post. IMO no need for a lift, but having it on ramps gave a nice bit of room underneath. Cheap and relatively easy.
Old Jul 14, 2013 | 06:17 AM
cristo's Avatar
cristo
Alliance Member
Anyone not had a leaking crank sensor o-ring yet on a R53 or R50?
Old Jul 14, 2013 | 07:55 AM
fr0mmagna's Avatar
fr0mmagna
*knock on wood* pick me! No leak yet. At 114xxx miles.
Old Jul 14, 2013 | 10:17 AM
ACallahan's Avatar
ACallahan
Frommagna have you got under your car and looked ? usually it is a very small leak but happens on almost every 1st gen. especially if you are over 100k
Old Jul 14, 2013 | 10:23 AM
baznight's Avatar
baznight
Mine hasn't started leaking yet on a "02" MCS but I will tell ya I have and oil pan gasket and cranksensor o-ring set aside cause I know it coming lol.
Old Jul 14, 2013 | 09:24 PM
fr0mmagna's Avatar
fr0mmagna
I was under there about 3 weeks ago for an oil leak. It was the seal on the oil filter tho.. broke free about 4500 miles after previous oil change. Must have hit a real good bump?! No oil leaks anywhere else, its real clean down there. Swapped my SC at 92k miles and that's when I cleaned all previous gunk left unattended by PO. Nothing was new and it wasn't even that bad. I do not lose oil between changes and its always very clean when I changed it. I'm very thankful for this !!!
Old Jul 16, 2013 | 05:47 PM
Rich.Wolfson's Avatar
Rich.Wolfson
I agree that it probably is everyone has or has had that leak. And it is easy to fix.
BUT you should consider an upgrade to the balancer while you are there. Those all eventually go too and the ATI Balancer is much better than OEM. Occasionally ATI sells some blemished units as a significant discount. Just cosmetic problems and when I got mine, I couldn’t even find it as it looked perfect to me.
///Rich
Old Jul 21, 2013 | 06:16 PM
purplehaze05mcs
I went to Pelican Parts website trying to find the CPS o-ring with no luck. Found only complete sensor w/o-ring. What's the part number? Is that dealer item only?
Old Jul 22, 2013 | 05:06 AM
cristo's Avatar
cristo
Alliance Member
should be 12147514983 Look it up on realoem, then plug the part number into the pelicanparts search box.
#9 here: http://www.realoem.com/bmw/showparts...82&hg=11&fg=10
pelican link: http://www.pelicanparts.com/cgi-bin/...FILTER_928M=ON
Old Jul 22, 2013 | 05:50 AM
tbearmini's Avatar
tbearmini
Unless you are ordering extra stuff from a vendor, that's probably something to get from your local dealer so you don't pay shipping. $4.
Old Jul 22, 2013 | 05:41 PM
purplehaze05mcs
Thanks everyone. I found it locally.
Motown
Apr 20, 2018 09:31 AM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
JPMontes3
Aug 23, 2015 01:26 AM
PSIChocolate
Aug 13, 2015 12:46 PM
