R50/53 I dont know whether to laugh or cry - LCA bushing install gone crazy
Old Jul 13, 2013 | 06:56 AM
simplyj's Avatar
simplyj
So after hours of wrestling with the housing bolts and then the the housing... sweating, bleeding and cursing away. I finally get to the point of installing the new bushings! If you think Im in the home stretch, think again! I take the pre pressed bushings out of the box from Way and go to install the driver's side and something is wrong. It's frigging pressed in backwards! Now I have to figure out some way to get these things out and swapped. I'm never getting this thing off jackstands.
Attached Thumbnails I dont know whether to laugh or cry - LCA bushing install gone crazy-image-523060725.jpg
Old Jul 13, 2013 | 07:09 AM
Braminator's Avatar
Braminator
Call Way.
Old Jul 13, 2013 | 07:12 AM
simplyj's Avatar
simplyj
I did already. Left a message. Unfortunately it is Saturday and they apparently aren't open. Doesnt help me much
Old Jul 13, 2013 | 07:28 AM
Braminator's Avatar
Braminator
IF you do try to get them out be careful you don't ruin them. Hopefully Way can get back to you ASAP. Good luck
Old Jul 13, 2013 | 07:35 AM
GreekDrifter91's Avatar
GreekDrifter91
do you have a vise or a press? use a socket the size of the hole in the housing. back side facing the bushing, then either two small blocks off wood or if you have it a even larger socket to place on the other side, put it in your vise and start cranking down. thats how i get almost every bushing out.
Old Jul 13, 2013 | 08:59 AM
simplyj's Avatar
simplyj
Nope no press (which is why I got the pre pressed in the first place). The few machine shops that are open on a sat wont touch it. Only option is to drive 2+ hours round trip to prestige mini and get oem. Mistakes happen but I didn't expect this from a mini specialist shop.
Old Jul 13, 2013 | 09:10 AM
Braminator's Avatar
Braminator
Go to any car repair center/shop as I am sure they have a press.
Old Jul 13, 2013 | 09:15 AM
simplyj's Avatar
simplyj
Tried 9 places in the past hour. Only one guy said he would give it a shot but didn't have the fitting to press it out with any hopes of not damaging it. No matter how much I begged and said I wouldn't hold them responsible for damage, nobody else would touch them. I've exhausted every local shop that I could find local today.
Old Jul 13, 2013 | 09:16 AM
GreekDrifter91
not even a bench vise huh. but you should try to see if a local garage can do it for you.
Old Jul 13, 2013 | 02:47 PM
mgrant's Avatar
mgrant
That sounds like a pain ... Just ordered my powerflex bushings from way also, i hope they'll be done correctly as i dont have a press either
Old Jul 13, 2013 | 05:07 PM
MINIdave's Avatar
MINIdave
Are you sure it's wrong? The first set I installed I thought we're wrong too, but I kept fiddling with it and figured how it went, then it turned out it was right after all.
Take another look at it.....
Those bushings just push in, if you can get a big hammer and a couple blocks of wood you can knock it out and back in again
Old Jul 14, 2013 | 05:43 AM
JAB 67's Avatar
JAB 67
Send Way a picture. He monitors his mail and this forum pretty much 24/7.
Old Jul 19, 2013 | 06:16 AM
simplyj's Avatar
simplyj
Finally got this done! Turns out that I should have just paid more attention to how I took them off at 3am as it was user error and nothing on the part of Way. Thanks to Way Motorsports and his explanation to me, I was able to finish the install last night.
It's amazing how smoothly things go with a little rest and a clearer head. Was able to get out of work a little early yesterday and tackled this install as well as installed new camber plates, R56 front brakes, and an Alta Diverter/water spray system. Did that and got the car back together in about 3 1/2 hours. I'm very happy, the car no longer wanders under hard braking and the front end feels very tight.
Old Jul 19, 2013 | 07:16 AM
v10climber's Avatar
v10climber
Glad Way was able to help you get it sorted out. I'm floored that none of the local shops would touch it. It's just a poly bushing. It's not particularly hard to get in/out of there. It's the stock one that's a pain to press out and you need a shop press for. I've done enough bushings/wheel bearings on my and friend's cars I just bought a shop press. $200 for a press and drivers and I've not come across anything yet I couldn't press out.
Old Jul 19, 2013 | 09:05 PM
mgrant's Avatar
mgrant
did mine this week ... boy does it make a difference !!!
Old Jul 19, 2013 | 10:28 PM
DRoc7822's Avatar
DRoc7822
This seriously sounds like something I have experienced a million times before. Not with bushings... but just the whole experience in general. Glad you got it figured out though.
Old Jul 20, 2013 | 07:04 AM
kaneguy's Avatar
kaneguy
Yep, when you progress to the cursing and tool tossing mode it's time to take a step back get some rest, have a beer or two to clear the head. Then come back to the task at hand with new vigor, it always surprises me how much easier the job really was.!!!!
silence2-38554
Nov 12, 2015 09:39 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
