R50/53 Mini not cranking and starter is brand new
Old Jul 11, 2013 | 09:26 PM
BluR53's Avatar
BluR53
Hey guys,
I am hoping that somewhere there is someone that can give me some amount of guidance...
The other day I went to my car to head to class and it wouldn't start. There was no starter noise at all or anything. So the obvious assumption was that the starter was bad. We took the starter off and brought it in to have it tested, it failed the test and I cheered. Ordered a new starter and installed it today and I still have the same problem...the starter isn't making any noise what so ever.
My battery is fine, it was just replaced a few months ago. My car was working just fine the day before.
I am stumped and scared that I am no the proud owner of a 2000 lb paper weight.
Please offer up any advice you might have
Old Jul 12, 2013 | 07:15 AM
Braminator's Avatar
Braminator
Just because its a fairly new battery does not mean it is OK. Get it checked out anyway. Check the battery connections.
Old Jul 12, 2013 | 07:21 AM
BluR53's Avatar
BluR53
Connections are good...battery has more than enough juice to turn the starter...still no starter.
Old Jul 12, 2013 | 08:42 AM
MIKESGREENMINI's Avatar
MIKESGREENMINI
Can you turn your headlights on? Check the voltage in the battery with a meter. If that checks out could be a fuse if your starter was bad maybe blew a fuse the last time you tried to start it.
Old Jul 12, 2013 | 09:17 AM
BluR53's Avatar
BluR53
Yeah the headlights turn on. The fuses are all good (checked those out right after the new starter didn't work) I am thinking it may be a bad security module in the car. So far that is my best guess...but I just want to know if others have ever had this problem. My clutch sensor switch is working correctly.
09R56
Nov 16, 2022 10:49 AM
CM2011RG
Apr 12, 2016 12:44 PM
Toolman
Jan 20, 2016 06:50 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
