R50/53 What to clean radiator and a/c coils with?
Old Jul 9, 2013 | 05:53 PM
pedalquickly's Avatar
pedalquickly
I have the radiator and a/c coils loose (well partially) and would like to clean them before putting them back. Whats the best and safest stuff to use that will give them that new look again?
Thanks..
Old Jul 10, 2013 | 01:36 AM
Eric_Rowland's Avatar
Eric_Rowland
Can't think of anything that will make them *look* new, but a soft long bristled brush should get out all the bugs.
Old Jul 10, 2013 | 03:47 AM
Cenla Mini's Avatar
Cenla Mini
Not sure how it will make them look but you can buy coil cleaner used for HVAC systems. This is only one example you can get a Walmart...http://www.walmart.com/ip/Frost-King...19-oz/20703057 ...it is for both HVAC and can be used for car radiators.
Old Jul 10, 2013 | 03:53 AM
pedalquickly
Thanks, I'll give it a try..
Old Jul 10, 2013 | 04:30 AM
GreekDrifter91's Avatar
GreekDrifter91
steam clean?
Old Jul 10, 2013 | 11:25 AM
bmwr606's Avatar
bmwr606
simple green makes a product for aviation that is safe on aluminum ... i use it at work
never use the original simple green on aluminum, it causes corrosion
scott
Old Jul 6, 2014 | 01:39 AM
flashyroadster9's Avatar
flashyroadster9
scott
Can you advice on this one called "Nar-Coil" made by Gur Technologies? I see it says "safer and less corrosive than HF-based cleaners"
Is this one safe for aluminum despite claiming itself to be less corrosive?
Old Jul 6, 2014 | 01:51 AM
bmwr606's Avatar
bmwr606
Is this one safe for aluminum despite claiming it itself to be less corrosive?
don't know about it
Old Jul 6, 2014 | 06:07 AM
Fly'n Brick's Avatar
Fly'n Brick
Use caution buying a coil brush. I bought one from the local appliance repairman and paid him a whopping $10.00 for it. I make sure it gets used very often during bug season to help amortize the near crippling cost.
Old Jul 6, 2014 | 08:18 AM
buzzsaw's Avatar
buzzsaw
I cut to size a piece of window screen and bordered the edges with aluminum tape for the bottom portion of the assembly. For the upper/accessible part of the assembly I just clean as nessecary. The brush that Fly'n mentioned works the best.
Old Jul 6, 2014 | 08:48 AM
ZippyNH's Avatar
ZippyNH
This will not only keep the bugs out, but also provide SOME protection from road debris...sand and tiny stones.....can destroy a radiator/condensor....many commercial vrchiles have been sold for years with a screen...they typically last 1,500,000 MILES ON THE ROAD OR MORE....so simple things that add life to parts are used to lower costs.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
doug5g
Sep 2, 2015 04:53 PM
