Newbie! Best all around spring/shock combo for aggressive s
Old May 2, 2004 | 02:24 PM
Morefun's Avatar
Morefun
Any input would be appreciated! New to the Mini. I've been doing DEs and track events 2-3 times a year since '96 in my '90 Carrera2. TheC2 has Bilsteins HDs and H& R coilovers along with a good alignment and weight balancing. But it's a daily driver and is compromised for the street. Is there a "proven" suspension setup for such an application for a MCS?
Old May 3, 2004 | 06:58 AM
ubercooper's Avatar
ubercooper
2 choices, koni's and h-sport springs with rear camber links and rear sway bar
or leda's full coil overs. The leda are supposed to be quite rough.
I have the koni/h-sport combo and it is harsher than stock but not too bad until you go to 1/2-full firm on the dampening.
Ubercooper
Old May 3, 2004 | 01:13 PM
Alex@tirerack's Avatar
Alex@tirerack
I have heard H sport /Koni being the best setup with your ride quality and look balanced!
Alex
Old May 12, 2004 | 09:59 PM
AMPR's Avatar
AMPR
Alex,
Would you mind sharing your thoughts on the Koni's? I just installed the Eibach pro kit and would likely put Bilsteins on my Mini if they were available. Unfortunately they're not so I'm considering installing Konis instead.
Thanks!
>>Alex
Old May 12, 2004 | 10:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Morefun,
Aloha and welcome to NAM. For a full suspension mod advice and for the most adjustability call-
Randy Webb at Webbmotorsports.com 720-841-1002
http://www.webbmotorsports.com/suspension.php
Eric Savage at Helix13.com at 1-877-HELIX13
http://helix13.com/html/products/suspension.htm
Rspeed.com at 888-551-0025
http://www.rspeed.net/mini/subcat.asp?dept=12&cat=3
All sell various products and have lots of experience.
Sounds like H-sport springs/Koni adjustable struts/shocks with H-sport camber plates in front and full 4 rear adjustable control arms in rear plus H-sport tubular competition rear adjustable swaybar.
Good luck
Old May 13, 2004 | 12:03 PM
Alex@tirerack
Koni Sport are one of my favore applications. They have a lifletime rebuild warranty - meaning - wear them out, Koni will rebuild them forever, as long as your the original owner.
Thew part I like the best is that the compression damping on the Sport is fixed - while the rebound damping is adjustable. For street vehcles you "usually" would not adjust the compression as a heavily damped compression stroke results in feeling major feedback - AKA being beaten - wich is fun on a track where pavement is next to purfect. ( except the corners of Mid Ohio - just kidding )
What your adjustment allows is full rebount control - Rebound is after the impact caused the springs to be compressed - the action of returning back to normal size. You can pick a lesser damping - for a plus ride - or a fimer damping for the reduction in roll - the ideal performace setting.
All the while you adjust it yourself witha basic dial tha drops right on the shock - adjustment takes about 3 minutes for the whole car!
Alex
Old May 13, 2004 | 12:30 PM
scobib's Avatar
scobib
I like the H&R spring/Koni adjustable/H&R 19mm rear swaybar setup, personally... like the slightly lower stance on the H&R's. Adjustable camber plates up front and adjustable control arms from any vendor you'd like...
Since the rear Konis are impossible to adjust without dropping the struts, I'd ask Randy Webb or the people in the auto-x forums what they like the setting to be in the rear...
Old Oct 25, 2005 | 09:06 AM
Android993's Avatar
Android993
Nothing aginst any of the other shocks, I have Koni on two other cars (old ones), but its a set it and leave it alone. If you like to play with your settings the Koni/Bilstiens are great since you can dial them in or out, which I have on another. Each have their pro/cons (minor), and Bilstien has a life time warrantee as well. I'm going to go out on a limb and try the Tein shocks with the EDFC unit that lets you dial the settings from the dash. Most of the new cars (expensive) out there are going to a electric shock configuration for street or track. Maybe when I was younger I didnt mind pulling the Koni's out (old school) and changing the setting, but now I'd rather be driving it. My $0.02 worth.
Old Oct 25, 2005 | 09:15 AM
kyriian's Avatar
kyriian
let me know when you have em... because that'd be the replacement for my setup when they go down
i have eibachs and konis, they ride pretty stiff, but handling on them is phenomenal
Doc Pain
Mar 10, 2021 04:50 AM
smdmini
Oct 7, 2019 06:05 AM
simo711
Oct 8, 2015 07:07 PM
Emnotek
Sep 29, 2015 07:37 AM
OutMotoring
Sep 8, 2015 06:27 AM
