R61 Paceman Toggle Switches?
I was at a dealer on Saturday and none of the Paceman on the lot had a complete set of toggles. there was always one slot empty. Is it possible to get a complete set when ordering? If so what options need to be ordered to get a complete set? Thanks
I was just wondering that the other day too, thanks! I read a post about a heated windscreen, but now that I look again, that option is in one of the round buttons, not a toggle. So on my car the far left round button is a fake and the second from the left toggle is gone.
Photo of European toggles. The second toggle from left is auto start-stop, not available in North America. The blank round button is for windshield heater, available in Canada but not the U.S.
From what I see on RealOEM, you coul buy the one toggle missing for 8$. Now, can this be installed in the cluster as-is? Can't say
You can install the missing toggle but it is not a switch in the sense that the toggle does anything. The toggle actually presses of the 2 small buttons on a printed circuit board behind the toggle. You cant use the "extra" toggle to add anything after-the-fact. For the $7-$10 most vendors sell it for, it fills the area out nicely.
My guess is that you would at minimum have to drill out the plastic. Hopefully there are still mounting studs for it behind.
And if that works, it will only press the existing PCB. But combined with fes's auto-sport circuit, if all of these things are true, then each could be used to toggle an accessory and still look stock. (That's a lot of ifs)
Once the cover is off, there are two little plastic flaps or prongs that go over raised parts of the cover panel and the blank pops right off with a small pry or screwdriver that techs carry in their shirt pocket.
No drilling, just tactful pulling and prying. The new toggle just pops right into the board at the fulcrum point and it will press the two micro switches on the board and do nothing.
F55/F56 Do I have rear fog lights?
Peking Duck
Jan 19, 2021 03:17 AM
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
gnhovis
Sep 28, 2015 04:07 AM
I would to see how this turns out. My Paceman has a blank as well and I could think of a few things I might add in that position.
