R50/53 How to determine month of build
Old Jul 7, 2013 | 06:37 AM
pedalquickly's Avatar
pedalquickly
I am about to purchase a clutch kit from Pelican, but it appears there are kits up to april of 06 and then after april of 06. How do I determine which lit I need? I have a 2006 Mini Cooper S and the last digits of the vin are TL17056.
Old Jul 7, 2013 | 06:40 AM
Braminator's Avatar
Braminator
Look on the inside of the drivers side door jamb. Notice here in the picture it say 03/00. That is the month and year it was built
Old Jul 7, 2013 | 06:52 AM
pedalquickly
Thanks...this forum is awesome and so helpful..
Old Jul 7, 2013 | 06:54 AM
Braminator's Avatar
Braminator
You are welcome. Now go motor on!
Old Jul 8, 2013 | 04:54 AM
pedalquickly
I looked for a sticker like this on my car and there are no stickers at all in the door jambs or the door. There are only a couple of stickers under the hood. One is identifying the color and the other has to do with emissions. Is the VIN # supposed to be on the drivers side where you can see it thru the corner of the windshield from the outside? There is a little window there but it is blacked out??
Old Jul 8, 2013 | 07:26 AM
Braminator's Avatar
Braminator
It should be just like the one I posted. Call a MINI dealer and give them the VIN# and see if they can tell you.
Old Jul 8, 2013 | 09:01 AM
GreekDrifter91's Avatar
GreekDrifter91
go to realoem.com and put your vin in it will tell you there. you are a 10/2005 and you will find diagrams and part numbers here
http://realoem.com/bmw/select.do?vin=TL17056
Old Jul 8, 2013 | 09:44 AM
+1 TL17056 - Last 7 digits are determine a 10/2005 build.
Clutch Kit
http://www.ecstuning.com/Search/SiteSearch/21207551384/ES40942
Recommend to replace the guide tube as they can show some wear. I have seen ones in the past with some wear on the tube grooved pretty bad. The release bearing should slide smoothly on this when it pivots on the clutch release fork.
Guide Tube #1 in diagram
http://www.ecstuning.com/Search/SiteSearch/23117551719/
Also check for leaks from the shaft seal, since you are in there and have things apart these can sometimes leak. It sets behind the guide tube towards the transmission.
Shaft Seal # 2 in above diagram
http://www.ecstuning.com/Search/SiteSearch/23117518633/
And the flywheel for the stock clutch.
The Flywheel "Twin Mass" also referred to "dual mass".
Twin Mass Flywheel Part number 21207532057 There is Genuine MINI and the Luk brand.
http://www.ecstuning.com/Search/SiteSearch/21207532057/
Thanks and hope that helps.
Old Jul 8, 2013 | 05:51 PM
pedalquickly
Thanks for all the info. Yes I did find out by calling Mini that my build is Oct 05. I have purchased the new clutch, pressure plate, throw out bearing and slide tube but forgot about the front trans seal. How difficult is it to get out? Any suggestions?
Also what does "Dual Mass" flywheel mean? I didn't know anything could be dual mass like that?
Old Jul 9, 2013 | 05:22 AM
ZippyNH's Avatar
ZippyNH
Dual mass...means it has a weight that can move...couple different designs...one is springs...they cannot be resurfaced....many folks switch to a std flywheel to save $$....but increases idle vibration a bit.
Old Jul 9, 2013 | 06:25 AM
pedalquickly
So it sounds like it has the capability to self balance?
Old Jul 9, 2013 | 12:01 PM
ZippyNH's Avatar
ZippyNH
More or less....
But net result is it tripples the cost of a clutch job....price it out....it cannot be machined. If user did not slip the clutch and leave the face in bad shape you MIGHT be able scotchbrite the surface and use it....but the clutch itself can have the weights get stuck as they age....gives the car a sound of a "Chewbacca" roar when idling....when stuck...most likely on cold AM's it seems.
twistedimages
Sep 19, 2024 04:13 AM
Teh
Jun 13, 2018 02:59 PM
F55MidnightBlackCooperS
Navigation and Audio
37
Apr 14, 2016 12:55 PM
David.R53
Sep 1, 2015 06:51 PM
MES11
Aug 8, 2015 10:21 AM
