Advice Needed Please
Old Jul 4, 2013 | 12:27 PM
kingbc's Avatar
kingbc
I picked up a set of wheels second hand and should have done a more thorough examination before buying them. Now that I'm about to get some tires mounted on them I've noticed that two of them have some damage on the outer lips. Visually I'm not concerned as wheels get banged up anyhow and I don't see running these for more than a year or two anyhow. The question is; should I bother getting these fixed before mounting tires or will they balance fine as they are?
Any advice would be greatly appreciated!
Thanks in advance.
-Bill
Old Jul 4, 2013 | 12:33 PM
Braminator's Avatar
Braminator
IF they hold air you should be ok. I would have them fixed or go back to the seller if you can.
Old Jul 4, 2013 | 01:56 PM
kingbc's Avatar
kingbc
I've been sitting on them for almost a year, so i'm an owner at this point. I'll see what Discount has to say when I bring them in.
Thanks for the input.
Old Jul 4, 2013 | 05:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I would suggest getting an estimate on repair of both wheels before mounting tires.
see
http://www.awrswheelrepair.com/
check for a local rep
http://www.awrswheelrepair.com/locator.html
Old Jul 5, 2013 | 06:11 AM
Reebus's Avatar
Reebus
I had a very slight bend in one of my stock wheels. It was so small that the onlly way to see that the wheel was bent was whie it was spining on the balancing machine. We could never get that wheel to balance. I would also suggest you look into getting them fixed before mounting.
Old Jul 8, 2013 | 11:06 AM
afadeev's Avatar
afadeev
-Bill
Bill,
I would worry about ability to balance them. Period.
I've done my share of wheel bending (NYC roads), and the way you know you bent the wheel before getting out of the car is from the wheel vibration. Looking at your pics, wheel #1 is very likely to shake badly that no amount of weights will counter-balance.
Fixing will run you $200-300, plus shipping.
It may be cheaper to find another 1 or 2 wheels of the same design, and buy them off eBay. Plenty of wheel repair shops sell their wares there now at far cheaper prices than it would cost you to fix your bent wheels - go figure.
Sorry about the bad news,
a
Melvinyip
Apr 17, 2020 09:28 AM
boostedhaze
Jan 2, 2018 07:26 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Herleman
Aug 16, 2015 06:41 PM
