R61 Rear Sunroof Doesn't Move
I'm pretty sure this must be a mis-print in the owner's manual, but it says that both the front and rear sunroofs should tilt up, and the front one should slide open. Only my front sunroof moves at all -- is that normal? The rear one is totally fixed in place. Can anyone else confirm how their sunroof works?
From the Paceman Manual:
Tilting
> Press the switch backward to the resistance
point and hold it there.
Both glass roofs are tilted.
Releasing the switch stops the movement.
> With the ignition switched on, press the
switch backward beyond the resistance
point.
Both closed roofs are tilted fully.
Pressing again stops the movement
Tilting
point.
We had a Paceman loaner for 2 weeks, the Countryman and Paceman share the manual and the CM has double tilt sunroof but the Paceman only had the front sunroof tilt and slide. When I was looking at it it seems the Paceman rear sunroof looks smaller than the Countryman one.
That's the first thing I noticed after taking delivery on my Paceman. The dealer said he thought the mechanism to open it was there (don't know how he figured that) but was not connected. The other Paceman on the lot also had fixed rear panels.
You do realize that this thread was 5 yrs old right?
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
xraycat
Aug 12, 2015 02:36 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
