GP Alignment
Old Jul 1, 2013 | 08:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
GP Alignment
Has anyone else put their GP on the Alignment Rack? We put our GP on the rack to see what it was.
Stock: Camber
LF RF
-2 deg -1.8deg
Rear was right at -1.6deg.
Kinda Curious to see if anyone else has and see what numbers they have.
I switched to some BFG tires, and added some Adjustable Hsport Rear Camber links.
Now alignment is -2deg on both front, and -1.4 both in the rear with less toe.
Old Jul 2, 2013 | 08:21 AM
quikmni's Avatar
quikmni
That is great stock camber. I am jealous, I had to add front camber plates to my 2006 GP to get to -2.0.
The -1.6 rear camber seems to be about the least negative you can adjust to with the stock adjustment with about a 1/2 to 3/4" lowering.
Which BFG tires did you go with? Was it the Rivals?
Old Jul 3, 2013 | 04:30 PM
akng's Avatar
akng
Anyone figured out what's the optimal height and alignment settings yet?
Old Jul 8, 2013 | 06:55 PM
k_h_d's Avatar
k_h_d
How is the GP getting -2 camber? Does it have camber plates?
Old Jul 8, 2013 | 07:49 PM
WayMotorWorks
Vendor
The GP upper strut towers are slotted to allow more camber.
I put the Hsport rear camber links to get my camber down.
As for tires I put the BFG Sports on my car.
Old Jul 10, 2013 | 06:16 PM
k_h_d's Avatar
k_h_d
So the strut towers are slotted more than the standard R56? Why not just extend the slots on an R56 instead of installing camber plates?
Old Jul 10, 2013 | 08:10 PM
FIRESTARTER's Avatar
FIRESTARTER
Stock: Camber
LF RF
-2 deg -1.8deg
What is the stock toe settings front and back and what is your toe settings now? Thanks
Old Jul 11, 2013 | 02:21 PM
WayMotorWorks
Vendor
Yes they are slotted way more than the standard R56, and if you want to you can slot the towers on the standard R56 to get more camber
Old Mar 15, 2018 | 02:27 PM
blue al's Avatar
blue al
How long are the gp2 slots
My roadster needs some additional camber to make the best use of the b16 PSS10 bilstiens,
I'm planning on keeping the oem topmounts for compliance on my local rough pot-holed roads
The car will be mine to the grave so not too worried about any enhancements
Not being to everyone's taste
Old Mar 20, 2018 | 01:30 AM
robbo mcs's Avatar
robbo mcs
GP slots are 24mm long
Old Apr 3, 2018 | 12:19 PM
favino1006's Avatar
favino1006
I had mine on a rack recently and it was -1.8 all the way around. I put some Vorshlags on up front and now I'm running -2.5 front and -1.8 in the rear. Car handles nicely on track. I've still got some understeer going on that I'd like to work out. I'm also still on a stock rear sway though..
Old Apr 3, 2018 | 12:56 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
So... would you recommend -2 front camber and -1.5 rear camber for a lowered daily driver? Or something a little more conservative like -1.5 front and rear?
Old Apr 3, 2018 | 02:57 PM
favino1006's Avatar
favino1006
Not sure if that question was directed at me... I wouldn't hesitate at all to run the settings you just mentioned on a DD though. Go for it
Old Apr 3, 2018 | 07:24 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Not really directed at anyone in particular, but since you answered... -1.5 camber all around, of the -2 in the front?
Old Apr 21, 2018 | 02:33 PM
32 ft. per sec2's Avatar
32 ft. per sec2
Here's what I'm running:
- Pirelli P7 215/45 R17
- dropped the Bilsteins down to the lowest level with the following heights (measured thru centerline of rim on level garage floor to lowest point on fender lip, no driver, mostly full tank of gas)
LF 623mm/RF 626MM/LR 635mm/RR 635MM
Aligned 5 months ago to "stock" Mini GP specs per BMW:
Front Camber L -1.9/R -1.8 deg
Front Toe L/R .05 deg
Rear Camber L -1.9/R-2.3 deg
Rear Toe L .10/R .20 deg
Thrust angle .01 deg
I do notice the back end breaks loose/feels loose on sharp corners w/acceleration, kinda like it wiggles out if you know what I mean.
Old Apr 10, 2019 | 02:02 PM
ckussoff's Avatar
ckussoff
With the -2.5 front and -1.8 rear does the car rotate more? I am at -2.5 front and -1.5 rear very stable but no rotation.
Old Mar 3, 2020 | 12:27 PM
Babayaga's Avatar
Babayaga
Sorry to revive an old thread, but needed to ask some questions pre trackday!
Is there a reason why the camber numbers arent the same from one side to the other? Seems to vary greatly from one side to the other on the rear.
Same for the rear toe.
Also are the rear toe numbers positive degrees?
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
daviday
Sep 25, 2015 01:31 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
