R52 HELP! No 3rd and right rear brake lights now....
Old Jun 29, 2013 | 11:33 AM
nansumner's Avatar
nansumner
I have a 2008 convertible and, earlier in the week, I attempted to install the "Give Me a Brake" mod. If you google "'Give Me A Brake' mini", you can see the installation instructions. Per the instructions, I attached one end of the splicing adapter to the black/blue wire on the tail light connector plug. Then I attached the other end of the adapter to the yellow/black wire into what I figured out after the fact was the wrong wiring harness. (I was supposed to be splicing into a yellow/brown wire.) At this point, all the brake lights worked except the "Give Me a Brake" light in the rear bumper. Then I found another wiring harness and attached the end of the splicing adapter to a yellow/brown wire. (The other end was still attached to the black/blue wire on the tail light connector plug.) At this point, the 3rd and right rear brake lights wouldn't work. I have removed the splicing adapter from both wires and the brake lights still won't work. HOWEVER, the right rear tail light works when I turn on the headlights. The right signal light works too. I am now just trying to get the right rear and 3rd brake lights to work again. HELP please!! Thanks in advance.
Old Jul 3, 2013 | 06:44 AM
nansumner's Avatar
nansumner
P.S. The left rear brake light still works. It's just the right rear and 3rd bake light that will not illuminate. Thanks.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
