Drivetrain Coopercrap R60 Exhaust worth it or not
Old Jun 24, 2013 | 06:49 AM
pidge1114's Avatar
pidge1114
Looking at the Coopercrap exhaust. Looks to be half of what other cat back exhausts cost, but I don't see much info about it on here.
It also appears that it doesn't use a muffler at all, just a pipe straight back from the first cat through the midpipe. I'm assuming that isn't exactly going to pass emissions.
Any feedback/opinions on this exhaust, good or bad?
http://coopercrap.com/r60-exhaust.html
Old Jun 24, 2013 | 08:50 AM
sbdubya's Avatar
sbdubya
The muffler shop that installed my Magnaflow said that turbo engines really don't need a muffler because your exhaust is sent to the turbo. They even offered me this kind of setup to try out but like you I questioned the ability to pass emission testing that we have here in CA.
Good luck with your decision.
By the way my Magnaflow exhaust out the door was roughly $400. It is not the kit from Magnaflow but what the shop pieced together and it is the same muffler that is in the kit. The ceramic coated tips added $90 to the expense.
Old Jun 24, 2013 | 08:53 AM
pidge1114's Avatar
pidge1114
Which Magnaflow exhaust did you get?
I am pretty sure I could add a muffler to the Coopercrap exhaust in place of the midpipe.
Old Jun 24, 2013 | 10:26 AM
kerrys914's Avatar
kerrys914
I have seen #10435 added to the CM with good results.
https://www.northamericanmotoring.co...haust-r60.html
Old Aug 1, 2013 | 09:01 AM
Handersen8's Avatar
Handersen8
Hey guys,
I have the Cooper Crap exhaust on my r60. Sounds good, doesn't resonate and in sport mode, it has the best burble and pop. For the money, it's your best bet.
Old Aug 1, 2013 | 09:05 AM
JoanieB's Avatar
JoanieB
Write to CooperCrap and ask them. They are in Calif, they will know if it passes emissions.
Andy is a friend of mine, and he is a stand up guy.
Old Aug 1, 2013 | 07:50 PM
pyrrhusmj's Avatar
pyrrhusmj
How was the install? Any cutting involved?
Old Aug 1, 2013 | 07:52 PM
pyrrhusmj's Avatar
pyrrhusmj
Nevermind, I just read that it comes with a tube cutter.
Old Aug 1, 2013 | 10:00 PM
Handersen8's Avatar
Handersen8
Install wasn't too bad. I did a friend's with him. Mine is Andy's first build that was on his white countryman. Three cuts, one to remove the muffler tips, etc., another two to remove the resonator.
Old Aug 15, 2013 | 07:47 AM
demon510's Avatar
demon510
an exhaust shop can give you the same results for a cheaper price. just make sure they use 409 tubing and 309L filler.
Old Aug 16, 2013 | 01:34 PM
pyrrhusmj's Avatar
pyrrhusmj
Just had mine installed. Welds are great. Overall quality is good. Sound is fantastic with the resonator delete. I do still have my 2nd cat. I do have a complaint and it might just be the unit I have. the tips stick out about 2 inches from the bumper. That will be getting changed with new tips in the future with some black tips further back on the pipe. The shop could have fixed it by moving my tips back, but I figured I want Dimisa tips anyway.
Demon510 is correct though, a shop can probably build you one cheaper. My shop quoted me about $400.00 total. I know others have had even cheaper quotes. Considering I bought mine from someone who went a different way and labor was a hundred, I came out cheaper. That will all change when i want to change out tips though because of the extra labor (not counting tip cost since that is on me)
Old Aug 25, 2013 | 05:38 PM
uvaggio's Avatar
uvaggio
The Cooper crap sounds great, but a lot of drone sound.
Old Mar 7, 2014 | 04:05 PM
ayk07's Avatar
ayk07
i am thinking about the coopercrap for my r60, i hate the exhaust tips on it thought and how far the stick out but i will ask the shop to cut the dimisa tips from my stock exhaust and put it on the coopercrap. i cant ask for anything for 450 bucks. beats spending 1k.
Old Mar 7, 2014 | 05:09 PM
kerrys914's Avatar
kerrys914
I would just cut the 2nd cat and res out. It sounds really good and should cost less then $100 all in.
imanexcellentdriver
Aug 31, 2015 08:08 PM
Aug 13, 2015 12:57 PM
Aug 13, 2015 12:56 PM
Aug 12, 2015 01:24 PM
