Electrical Rallye 3000 headlights
Old Jun 21, 2013 | 08:40 PM
jrhavener's Avatar
jrhavener
ok,
so i've mounted the lights, i have a switch in the car.
i've got everything wired right i think, but i keep blowing fuses. the only part of the circuit i'm not sure about is the control circuit... where should i be getting my signal from?
i tried using the battery as a source... everything works but when i flip the switch the fuse pops
i have battery going to the switch part of the relay with a (currently) 10 amp fuse (i have 1 15A left, a bunch of 10s and 5s)
that goes to the switch side of the relay
the other side of the switch goes to the lights
the lights then have a ground.
the control side I tried grabbing the signal from the low & high beams, and the battery. either way i wired those to the coil side of the relay
the opposite side of the coil goes to the switch on my dash, then back out to a ground.
any thoughts? i'm hoping to get them working for MOT tomorrow, but I just finished a 14hour shift and I'm beat... any help is greatly apreciated, but i'm gonna have to call it quits soon anyways.
maybe next years MOT? lol
thanks
j.r.
Old Jul 15, 2013 | 09:22 AM
heresmymind's Avatar
heresmymind
you probably have a bad ground, or a bad circuit. what type of relay and wire harness did you use? and how did you hook it up
-B
Old Aug 8, 2013 | 03:34 PM
MotorWorf's Avatar
MotorWorf
I'm trying to locate a good ground under the driver's side knee panel for a driving light switch (has a built-in ON light)
Old Aug 8, 2013 | 03:50 PM
danjreed's Avatar
danjreed
You have a dead short somewhere if it blows when you flip the switch.. The short is between the relay's switch and the lights.
(Edit if wired as a power side switch..)
+ signal > 85 (relay) 86 > switch > ground
Battery + > fuse > 30 ( relay ) 87 > light > ground
I would take the + signal off the high-beam power wire. That way they will only function with the brights. (And be road legal).
There should be a good ground lug under the kick panel.. If not make one. Drill/nut/bolt
OutMotoring
Mar 3, 2017 06:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
