R50/53 installed lowerig spings
Old Jun 16, 2013 | 01:05 PM
trashmanbob's Avatar
trashmanbob
both me and my friend installed lowering springs on our mini's, we have felted a small shack on hard acceleration low end 1st gear. i remember a thread that talked about this but do not recall the out come
anybody help
Old Jun 16, 2013 | 03:51 PM
borderwave2's Avatar
borderwave2
anybody help
Some cars experience vibrations after lowering due to the axle position being changed. It usually happens on cars with more mileage. New/low mileage cars do not have this problem.
Old Jun 16, 2013 | 04:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If your using H&R springs we've found it to be very common with them. Otherwise check to make sure everything is assembled correctly.
Old Jun 17, 2013 | 04:57 AM
trashmanbob
shack
Thanks for your response, my car has 66k his 140k.
Old Jun 17, 2013 | 07:21 AM
uromini's Avatar
uromini
What would cause this with H&R springs and not others?
Their drop is pretty mild compared to others.
Old Jun 18, 2013 | 05:33 PM
LJcoop02's Avatar
LJcoop02
The angle of the axles change drastically when you lower it. You can either deal with it or go back to stock height. I have learned to accept it because, well, it just looks 10x better
Old Jun 19, 2013 | 09:00 AM
quikmni's Avatar
quikmni
I had H&R springs on my 2003 R53 with no issues.
I would suspect something is loose such as top strut nut or end link nuts.
Also make sure the springs are turned correctly to be properly aligned in the spring perches (end of springs touching bump in perch).
Old Jun 19, 2013 | 06:01 PM
trashmanbob
thanks, it was checked on both cars everything tight
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
