Hurry! Help for Removing the front suspension!
Old Jun 15, 2013 | 12:10 PM
kingblackfoot's Avatar
kingblackfoot
I want to replace my front suspension, and the guide I follow is http://www.pelicanparts.com/techarti...eplacement.htm. But in figure 10, I can not remove the 13mm bolts. Because when I try to remove the bolt, the wheel housing is moving at the same time.
Could you please help me with it? I'm in hurry because I'm on the half way of replacing the suspension.
Thank you.
Old Jun 15, 2013 | 01:56 PM
Eric_Rowland's Avatar
Eric_Rowland
Can't you just lock the steering wheel?
Old Jun 15, 2013 | 02:17 PM
JRhea's Avatar
JRhea
A compressor and and air impact wrench or a cheap battery powered impact wrench is invaluable. Those are only at 41lb torque so they shouldn't put up a fight unless you live in the rust belt.
Good luck
Old Jun 15, 2013 | 05:16 PM
kingblackfoot
Good luck
thank you for reply.everything was done.I just used a break bar.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
