R50/53 road tar HELP
Old Apr 29, 2004 | 10:25 AM
lotsie's Avatar
lotsie
Had to dodge the truck that sprays tar, road crack and small pot hole filler ,I was going 60 MPH ,got down to about 35 MPH ,but my rear view mirror filled up with a beater
1/2 ton who was not slowing down (probably sees the tar as free rust hole filler)so I ended up getting tar on the black trim :evil: non on the paint
_________________
03 MC BRG/W,15" 7 hole white...
Black Lab navigator
Old Apr 29, 2004 | 11:40 AM
Nick_T.'s Avatar
Nick_T.
lot15 - - -
I don’t know that there is a best product for tar removal. 3M Tar & Grease Remover (#39987) is my favorite, but many of the other tar removers are quite good, as is plain old kerosene.
The sooner that you deal with it the better. Try to keep it off of the paint as much as possible. Instead of spraying it on I saturate a small (3”-4”) square of cotton toweling with the remover and thoroughly wet the tar areas. Wipe off with clean terry toweling using minimum pressure. Repeat as needed. Then wash with your regular car shampoo and wipe down with 303 Aerospace Protectant.
Old Apr 29, 2004 | 12:02 PM
Koopah's Avatar
Koopah
I've had good luck with WD40. But like Nick_T, I immediately wash the trim and put on a coat of Vinylex or Back-to-Black.
Also, don't forget to check the front grilles and the top surface of your intercooler. You'd be amazed what can get stuck in those areas!
Theo
Old Apr 29, 2004 | 02:07 PM
lotsie's Avatar
lotsie
>>Theo
>> THANKS wd-40 was the answer .even the tar remover was barely working.I used a peice of sponge to apply a good soaking of wd,wait 2-3 mins. dabing to keep wet,then wipe off like butter
Old Apr 29, 2004 | 02:17 PM
CRZBRIT's Avatar
CRZBRIT
try gasoline or wd-40
Old Apr 29, 2004 | 02:21 PM
lotsie's Avatar
lotsie
>>After wd gas was the next choice.
thanks
Car Care Products
Dec 11, 2015 02:08 PM
IrishMCS
Dec 1, 2015 04:21 PM
sir5150
Oct 6, 2015 05:25 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
Sep 22, 2015 07:31 AM
