R50/53 Exhaust manifold gasket question
Looking at the new OEM exhaust manifold gasket, one side of the gasket is flat and on the other side is raised around each exhaust port.....Does anybody know if the flat side or the raised side goes towards the head??? or does it even matter ???.............Thanks
Okay,.. I looked it up. I was expecting some lettering like this side facing head... Nah
My book says this ".....installation is reversal of removal, noting the following points:
Apply some anti seize compound to the manifold bolts
Always replace the manifold gaskets with the raised edges of the gasket facing toward the manifold
Exhaust manifold fasteners: 18 foot pounds
Note: I was surprised my book did not mention a particular order to tighten the bolts in. Me, I would tighten them in some sort of X Patern
just to be safe
just to be safe
Thanks for that follow up! On that note, I couldnt find an answer anyplace and already installed it with the edges facing the head not the exhaust manifold ;(............ No leaks,.....YET???? All seems fine for now
Replacing Exhaust Manifold Gasket 2002 R53
just to be safe
just to be safe
just to be safe
just to be safe
-Luccia
888.280.7799 | 6am - 5pm PST
Good thread here , CooperSAZ noticed that the flared outside goes towards the rear of the vehicle.
" The old gasket will most likely drop away as well. Pick up and remove the gasket. Note the way it is placed on the engine. Make sure the flared out side is facing the rear of the vehicle. "
https://www.northamericanmotoring.co...y-blk-r53.html
http://www.ecstuning.com/Search/SiteSearch/11621174968/
https://www.northamericanmotoring.co...der-bolts.html
Sorry, I'm confused... I've read from the top, and it appears to me that there is conflicting info here (or perhaps I don't understand the terminology) Way, ECS, et all... Can you once again confirm which way the raised side goes towards?
Is the "manifold side" the engine side (front of car) or the pipe side (rear of car)?
Based on what CooperSAZ noticed the "old gasket was flared side to the rear of the vehicle" , manifold side rear on the car.
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
