R50/53 Wheel stud question..
Old May 31, 2013 | 09:07 PM
NWcooperS's Avatar
NWcooperS
I've done a search with conflicting answers, so here I am. I just picked up some montegi and found my stock studs are to big, they don't fit in the holes. So I'm wonder what thread pattern ill need, I'm thinking I will need 12mm X....... But I'm hoping someone here has ran into this and can tell me what i need. Thanks for your guys help!
Old May 31, 2013 | 09:36 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
What you describe does not add up.
2006 MCS should have M12x1.5 lug bolts OEM. The bolt locks the wheel onto the hub.
What you describe is your lug bolts are too thick for the new wheels which suggests you have a 2007 R56 MCS using M14x1.25 lug bolts.
In any case you should email Way at Waymotorworks.com, he sells the various studs to fit.
see
http://www.waymotorworks.com/wheels/
Old Jun 1, 2013 | 07:07 AM
NWcooperS's Avatar
NWcooperS
Sorry, like I said I'm not sure what I need as the only two sizes I see for the bolt/stud style we have are 12mm and 14mm, I'm thinking now that its the diameter of bolt it self not the head? I'm used to the stud being on the hub. Thanks for you reply.
Old Jun 1, 2013 | 07:11 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
In the latter part of '06 the bolt size was changed to 14mm.
Old Jun 1, 2013 | 07:26 AM
Braminator's Avatar
Braminator
All bolts are M12 x 1.5 for MINIs with production dates up to 7/11/2006. After that it went to M14 x 1.5
Old Jun 1, 2013 | 07:39 AM
Redhatch's Avatar
Redhatch
Just open up the holes in the wheels. A 19/32 drill will work fine and give you about 1mm of clearance with the stud. You can do it with a hand drill but is best to use a drill press.
Old Jun 1, 2013 | 10:54 AM
minihune's Avatar
minihune
Yes, you can drill out your wheels to make the holes bigger but be sure to be perpedicular to the level ground. If using a drill press you have to lift up the wheel.
Otherwise you can use this stud conversion kit-
http://www.waymotorworks.com/m14-to-...rsion-kit.html
You install the 14mm side into the hub and use the 12mm side to mount the wheels. You'll need M12x1.5 lug nuts to fit the new studs, you wheel will fit fine.
Old Jun 1, 2013 | 10:57 AM
AlexQS's Avatar
AlexQS
If it were me, I'd take the wheels to a machine shop if drilling them were the only solution. The lug holes must be centered very precisely, and I don't trust myself to get it perfect... Maybe I worry too much.
I'd call Way at waymotorworks.com first. I'm pretty sure he has a kit to convert lug bolt size, and knows MINI Coopers as well as anyone you'll find. (He helped me a lot, and I bought some other stuff from him)
Old Jun 1, 2013 | 10:58 AM
AlexQS's Avatar
AlexQS
You beat me too it. Lol
Old Jun 1, 2013 | 06:17 PM
NWcooperS's Avatar
NWcooperS
It's not about drilling it out to make bolt go in the holes, it's about the tapered part of the head not fitting into the hole on the wheel.
Old Jun 1, 2013 | 07:09 PM
ZippyNH's Avatar
ZippyNH
Then the rims you are using needs either
1) tuner lugs...they have smaller ends...gorilla makes them...I have a set for one of my rims...
or
2) a stud conversion.....
either one must be in 12 or 14mm diameter to fit your production date...mini changed mid 2006.
khumpert
Nov 30, 2015 11:48 AM
MINI VINI
Oct 13, 2015 08:57 AM
madmaxxed
Sep 2, 2015 03:32 PM
rckrzy1
Aug 26, 2015 09:12 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
