Navigation & Audio Mini Connected w/Nav Volume
Old May 31, 2013 | 07:01 AM
sheldoncooper's Avatar
sheldoncooper
Hi, how do i turn up the volume on the turn to turn direction? i tried to turn up the volume while giving direction and it does work but then the music comes back up very loud... there is not an option for it? also on the mini connected up when i start it, there as well the voices are very soft...
Old May 31, 2013 | 07:11 AM
threar's Avatar
threar
I haven't found a specific setting to allow those to change; the way I fix it is much like you describe. During turn-by-turn when "she" starts talking I turn the volume up (via the the **** not the steering wheel). This should affect only "her" voice and not the music. That should work (as I've done it many times) but might take a little bit of experimenting.
Old May 31, 2013 | 07:17 AM
sheldoncooper
I will try again today, the manual also say that the setting should be saved with the key... and considering i use the same key should be good.. i guess we shall see...
ps where did you get your MC "cars" i'd like to get one too
Old May 31, 2013 | 07:53 AM
threar's Avatar
threar
For my signature picture, I went over to the "What if?" thread and found a base "car" that best matched my MINI. Then I photoshopped parts from other cars onto the image to make it much closer to mine.
Old May 31, 2013 | 09:14 AM
sheldoncooper
thats awesome, thanks!
Dec 23, 2015 10:36 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
noreen99
Aug 8, 2015 08:21 AM
tippin
Aug 5, 2015 08:43 AM
