R50/53 It is possilbe to replace inner ball joints without dropping the subframe?
Old May 30, 2013 | 07:15 PM
IQRaceworks's Avatar
IQRaceworks
I need to replace my inner ball joints on my lower control arms pretty soon. I don't mind taking the time to drop the subframe again (just did it last year when I put in new bushings), but if there is a way to replace the ball joints without dropping the subframe...I sure would like to try it.
Has anyone replaced the inner ball joints without dropping the subframe? If so...how?
Thanks!
Old May 30, 2013 | 07:59 PM
GreekDrifter91's Avatar
GreekDrifter91
yea you can take off the inner ball joints with the sub frame on. just take off the wheel and get in there with a breaker bar or impact gun. taking out the wheel liner will prob help too. mine where on there good. i didnt replace them i just had to do something else
Old May 30, 2013 | 08:05 PM
JAB 67's Avatar
JAB 67
I don't understand how you could access with an impact gun the bolts that secure the inner ball joints to the subframe; please explain.
Old May 30, 2013 | 08:15 PM
GreekDrifter91
ill have to take pics and mark it out but it is possible. Pics wont be available till Sunday though.
i dunno maybe my gun is small. but i did take off the inner ball joint because i took it off and forgot to put the bracket for the head light auto level when i had the sub frame out of the car(for another job). so when i notice it when i had buttoned everything up i was like F*** but i was able to get to it and unbolt it.
Old May 30, 2013 | 08:18 PM
GreekDrifter91
ig you cant get a gun in there use a breaker bar with long pipe. i had to break the torque this way first but when i retorqued them to spec i got them off with the gun the second time.
Old May 30, 2013 | 10:03 PM
element's Avatar
element
dropping the sub frame isn't that hard.. first time there's learning, but after that its really quick!
phil.
Old Jun 1, 2013 | 04:59 AM
mrbean's Avatar
mrbean
phil.
+1
You can lower it slightly without dropping it completely. When I did my passenger side ball joint, I was able to get the bolts out without doing anything to the subframe. I used a box wrench to loosen the bolts. Then I removed the engine brace that's right next to the power steering cooling fan so that the engine could swing back a forth slightly; just enough to allow the one bolt to clear the inner CV joint.
Alternatively, you can remove the axle assembly to gain access to the bolts.
Old Jun 1, 2013 | 08:42 PM
GreekDrifter91
hahahaha thats why i could fit a gun in there i didnt have the axles in at the time. but you can def get in there with a breaker bar.
Cereall
Sep 5, 2019 06:05 PM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
