R60 Which R60 All4 exhaust
Old May 30, 2013 | 09:07 AM
Elmj's Avatar
Elmj
I'm getting ready to upgrade my exhaust for 2011 CMS4 and was curious which exhaust system is recommended by owners, they all see to be similarly priced $1k ish, just looking for suggestions
Cheers
Old May 30, 2013 | 10:14 AM
ghamma's Avatar
ghamma
If you do a search in
MINI Countryman > Modifications > Cooper S Drivetrain
you'll find a lot of discussion of various exhaust system options.
Old May 30, 2013 | 10:26 AM
Mini-LSE's Avatar
Mini-LSE
Cheers
I am considering this too. I will keep you posted and please do the same.
Old May 30, 2013 | 10:43 AM
bmwr606's Avatar
bmwr606
i went with the milltek DP back exhaust and am very happy with it
https://picasaweb.google.com/1043068...eat=directlink
no cutting, replaces entire system from the downpipe back
uses the stock v-band clamp and stock exhaust mounts
eliminates the resonator and second cat
no drone at any speed/rpm
63.5mm (2.5") all the way from the DP
100mm (3.9") tailpipes
the sound is lower pitched than stock and slightly louder at steady speed but does not block out the radio
much louder than stock at WOT, but not ricer loud
power comes on 800-1000 rpm lower
scott
Old May 30, 2013 | 11:42 AM
Elmj's Avatar
Elmj
Ok will do
Old May 30, 2013 | 11:45 AM
Elmj's Avatar
Elmj
Would this still pass California smog ?
Old May 30, 2013 | 11:47 AM
Elmj's Avatar
Elmj
Old May 30, 2013 | 12:07 PM
MinneMINI's Avatar
MinneMINI
This is his car with the milltek BTW
Old May 30, 2013 | 12:12 PM
bmwr606's Avatar
bmwr606
Originally Posted by MinneMINI
that is me, but my camera really mutes the low tones ... this is a really poor representation of the sound
Old May 30, 2013 | 12:16 PM
bmwr606's Avatar
bmwr606
it should, the second cat is unmonitored (no O2 sensors)
OTOH, i did not get a smog sticker with my system
scott
Old May 30, 2013 | 12:25 PM
MinneMINI's Avatar
MinneMINI
scott
So where did you get this system? Did you get it from a dealer? Thanks!
Old May 30, 2013 | 01:21 PM
bmwr606's Avatar
bmwr606
http://www.milltek.co.uk/stockists.i...nited%20States
Old May 30, 2013 | 03:13 PM
tmdflh's Avatar
tmdflh
I have a JCW but absolutely want to buy a Quicksilver I think they are top notch look at the specs and craftsmanship that will tell you everything
Old May 30, 2013 | 03:23 PM
wzabrouski's Avatar
wzabrouski
Magnaflow here.
Old May 30, 2013 | 03:24 PM
wzabrouski's Avatar
wzabrouski
$800 from Summit Racing
Old May 30, 2013 | 03:53 PM
Elmj's Avatar
Elmj
I agree ,that the Quicksilver looks outstanding just not sure about 2k price tag vs benefit
Old May 30, 2013 | 06:04 PM
tmdflh's Avatar
tmdflh
Old May 30, 2013 | 06:11 PM
Mini-LSE's Avatar
Mini-LSE
Originally Posted by wzabrouski
Magnaflow here.
I am leaning in this direction. What are your thoughts? Any drone? Do you have any audio?
Old May 30, 2013 | 06:14 PM
iriedevil32's Avatar
iriedevil32
I went with Magnaflow.
Old May 30, 2013 | 06:27 PM
bmwr606's Avatar
bmwr606
be aware that any of the stock pipe that remains is 2.25" and any stock welds (ie at the flex pipe, front of and behind the resonator and second cat) are 2.125"
the milltek is 2.5" all the way from the v-band clamp back
scott
Old May 31, 2013 | 05:11 AM
Elmj's Avatar
Elmj
I also had it down to Magnaflow and NM engineering , there's You Tube vids of a Magnaflow exhaust sound it's nice ,IMO. I'm in Cali so I just want to be sure I'm good with any kind of smog compliance. Mini Mania has a video of the NM engineering exhaust being installed it looks very simple and also sounds good .
Old May 31, 2013 | 05:22 AM
Elmj's Avatar
Elmj
Here's the Magnaflow video
Old May 31, 2013 | 05:42 AM
MinneMINI's Avatar
MinneMINI
If you mean that is the magnaflow MUFFLER, then yes it is. But that video is actually 1Bigpea's CUSTOM magnaflow system with a magnaflow muffler and custom tubing etc...not the cat-back system that magnaflow sells online etc. That is here http://www.magnaflow.com/04sound/spo...ountryman.html
You can tell the difference right away. Hope this helps. Cheers
Old May 31, 2013 | 04:28 PM
Elmj's Avatar
Elmj
My apologies
Old May 31, 2013 | 04:36 PM
Elmj's Avatar
Elmj
The Milltek is around $1250 looks like a more complete system than Magnaflow and NM engineering maybe BMWr606 can tell us from the pictures he took if there are a number of connection points, it would seem to me you'd want to keep those to a minimum. It looks like even the tail pipes have "hose clamp" connection
