R50/53 Rear License Plate Light Housing
Old May 30, 2013 | 07:27 AM
Jat007's Avatar
Jat007
Hello Guys and Gals,
Can you all tell me where I can buy a new Rear License Plate Light Housing for my 04' Mini? I scanned Fleasbay and on the forums, but nothing jumping out so far.
Thanks,
--Jay
Old May 30, 2013 | 07:39 AM
Dependent on your options and version. The housing is rear handle.
"Chrome" version.
http://www.ecstuning.com/Search/51137074020/ES78095/
"Primed" Version: ( for painted rear trunk grips )
http://www.ecstuning.com/Search/51137075582/ES78098/
"Black" Version: ( for basic or black rear trunk grips )
http://www.ecstuning.com/Search/SiteSearch/51137167530/ES78252/
Trunk Lid Grip - JCW Carbon Fiber
http://www.ecstuning.com/Search/51130395503/
Lens pops out and the terminals corrode that holds the bulb. Its an all in one unit and install with four screws and plugs into the harness .
It you need just the lens : one is for each side.
http://www.ecstuning.com/Search/SiteSearch/51247114535/ES92096/
Old May 30, 2013 | 07:40 AM
minibx's Avatar
minibx
http://www.ecstuning.com/Mini-2004-C...Plate/ES78252/
Here is the whole assembly or you could get just the bulb covers if that's what you need
Old May 30, 2013 | 07:41 AM
minibx's Avatar
minibx
ECS is way too quick lol
Old May 30, 2013 | 07:43 AM
Jat007's Avatar
Jat007
Yeah, I replaced the lenses 2 years ago along with the light bulbs. Now, the metal contacts that holds the bulbs has broken off as I was trying to replace the light bulb )-:
It got so corroded - I guess, this is what I get for living in Minnesota (-:
Thanks guys!!
--Jay
Old May 30, 2013 | 07:45 AM
minibx, you were not too far behind.
Jay - Glad we could help.
Old May 30, 2013 | 10:10 AM
BlwnAway's Avatar
BlwnAway
Tip:
When you replace everything this time, get some led bulbs (for longevity and cooler operating temps) and silicone the lenses on, all the way around. This will greatly increase the life of everything by cutting down the grit & moisture.
Old May 30, 2013 | 03:54 PM
Jat007's Avatar
Jat007
Great idea BlwnAway!!
Thank you.
Old May 31, 2013 | 06:04 AM
scf's Avatar
scf
Check out my recent thread, especially post #11 by buzzsaw:
https://www.northamericanmotoring.co...-assembly.html
Old May 31, 2013 | 07:37 AM
BlwnAway's Avatar
BlwnAway
That's ok as long as your wiring is still good, you could also just but some pre-wired led's (ready for 12v) and solder the leads appropriately & seal it back up.
I had to replace the whole thing simply because mine had accually corroded the wiring to the sockets clean through.
boostedhaze
Jan 2, 2018 07:26 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
