Another Oil Leak
Old May 29, 2013 | 03:41 PM
mbwicz's Avatar
mbwicz
Another Oil Leak
I recently replaced my valve cover to replace an oil leak on my 08MCSa, 73k miles. After that, I rinsed down the engine really well. This weekend I put on an intercooler, and see that I have another oil leak. The car sat for a couple of days before I brought it in the garage, so there is actually a drip on the downpipe. The cylinder head is dry, as is the block below the oil filter. All of the oil pan bolts are tight.
It seems that there is a decent amount coming from the window in the trans bellhousing, but there is also some on a few oil pan bolts above the downpipe. I don't remember reading of any common leaks in this area.
Ideas?
Mike
Attached Thumbnails Another Oil Leak-may-sony-236.jpg   Another Oil Leak-may-sony-237.jpg
Old May 29, 2013 | 04:14 PM
MikewithaMini's Avatar
MikewithaMini
Your downpipe drips might be coming from turbo oil pipes.
Old May 29, 2013 | 04:47 PM
countryboyshane's Avatar
countryboyshane
Turbo oil supply and drain is a good idea. You should also check around the oil cooler for leaks as it's in the general vicinity too.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
