R50/53 Drain the Hatch
Old May 28, 2013 | 07:09 PM
Cobrabud's Avatar
Cobrabud
Drain the Hatch
Has anyone drilled a drain hole in the bottom of the hatch to drain any water that might get in there? My 2004 R53 is collecting lots of water, but I am going to put on a new gasket behind the license plate lights. Probably will have to replace the micro switch too. Does water get in around the third light too?
Old May 28, 2013 | 07:21 PM
minibx's Avatar
minibx
Read on this it could help you,https://www.northamericanmotoring.co...elf-fixed.html
I did change the seal on the boot handle and cleaned the connectors and the problem has been fixed, the seal is about 10.00 to 20.00 I put electrical grease on the connectors after cleaning no need to drill any holes IMO
Old May 28, 2013 | 07:22 PM
ZippyNH's Avatar
ZippyNH
3rd brake light..if it leaks...leaks into the body...it is ABOVE the hatch...
the hatch/trunk SHOULD have weep holes at the bottom of the panel...2 actually (just looked at my 2005)...one at the weld seal/bottom, about half way between the latch area and the end.
Mahatma Kane's Avatar
Mahatma Kane
The R53 came from the factory with drain holes in the hatch.
Old May 28, 2013 | 07:24 PM
ZippyNH's Avatar
ZippyNH
When my handle started to leak....i re-installed it...with both the old seal, and some gasket-maker...stuff looks kinda like rtv.
No issues with it...heck..i used some cleaner on the switch....dried..re-installed.
IF the rubber membrane on the switch is torn...just replace the entire handle IMO.
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
martinb
Oct 7, 2015 05:00 PM
MGBill1186
Oct 2, 2015 06:54 AM
dutchhome
Sep 30, 2015 07:17 AM
